bouncing rev counter on a mito evo
d-bug
PostPosted: 06:43 - 25 Jul 2009    Post subject: bouncing rev counter on a mito evo Reply with quote
i brought a mito evo yesterday and when the bike is stood still the rev counter seems fine but on the way home i must of been doing 7000revs and the counter bouncing around 2000revs , but all so the temp gauge is doing it , what could be making it do that ?
cheers d-bug
alun111
PostPosted: 06:49 - 25 Jul 2009    Post subject: Reply with quote
I'd give your charging circuit a check... search the forum if you're not sure how to do it.
d-bug
PostPosted: 10:50 - 25 Jul 2009    Post subject: Reply with quote
hey cheers for that , but i have had a look in the fourm and dont seem to find any think on it , but will keep lookin Confused
cheers d-bug
alun111
PostPosted: 13:56 - 25 Jul 2009    Post subject: Reply with quote
First of all, give your battery a full charge with a proper bike charger (or a car charger that charges at no more than 4 amps per hour)
Using a multimeter set to Volts DC (The next setting above 12v) you have to test the charging circuit.
Gain access to the battery and put the red probe from the multimeter on to the positive terminal of the battery and the black probe on to the negative of the battery. Take a reading. Note it down.
Turn the ignition on. The reading should slowly drop a little. If it drops a lot your battery's knackered.
Press the starter button - again take a reading. The battery voltage should not drop below about 9 volts. If it drops too low your battery's knackered.
With the bike running, take a reading of the battery at varying stages throughout the rev range. It should never go above approx 15v, or below 13v. If it does then your battery could be at fault, or you have a charging circuit problem with either wires, connections or the alternator/generator and/or regulator/rectifier.
I hope this helps. Good luck.
d-bug
PostPosted: 21:18 - 26 Jul 2009    Post subject: Reply with quote
ok cheers for that alun111 i changed the battery for a new 1 i brought a week ago and it still done it , and i found all so now that the bike is ticking over and it said i was doin 4000 revs , rite time to play around with the wires Neutral
cheers d-bug
the grim reaper
PostPosted: 11:55 - 27 Jul 2009    Post subject: Reply with quote
Check the connections on the back of the clocks for corrosion and also check that the regulator/rectifier is charging the battery at the correct rate and not overcharging it.
Grim
The last post was made 17 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 15 - Page Size: 47.96 Kb
