Should I replace all the sprockets and chain?
Do I need to replace the chain and the rear sprocket as well?
Just the chain and gearbox sprocket
10%
 10%  [ 3 ]
Just the rear sprocket and gearbox sprocket
0%
 0%  [ 0 ]
Yes, all three
90%
 90%  [ 27 ]
No, replacing only the gearbox sprocket is enough
0%
 0%  [ 0 ]
Total Votes : 30
joan33987
PostPosted: 22:38 - 25 Jul 2009    Post subject: Should I replace all the sprockets and chain? Reply with quote
OK, I bought a Stolen Recovered 2005 Honda CG125 few days ago with 29,566 miles. Last night, I opened up the gearbox sprocket cover and saw this (picture 1). OMFG.
Alright, the question is, Do I need to replace the chain and the rear sprocket as well?
The rear sprocket seemed to have some life left and the chain as well. Well I'm no expert in judging chain life but the gear box sprocket is well fuxked (and abused)
Today, I tried to move the bike using its own engine power, as soon as the clutch is partially engaged, the sprocket already started to slip! the bike didn't even move. LOL!!!
There are still plenty of adjustment on the chain BUT I HAVEN'T COUNTED THE ROLLERS ON THE CHAIN YET.
The poll will run for 5 days
current toys: Skygo SG125-J 125cc stolen again 1992 Kawasaki GPZ500S (crashed damaged) 1996 Renault Clio 1.2 2005 CG125 project
Timmeh
PostPosted: 22:54 - 25 Jul 2009    Post subject: Reply with quote
All three may as well be shagged.
For the price of a decent C+S set you might as well replace the whole lot in one go.
Using a wrecked/worn chain on new sprockets isn't a good idea, and vice-versa.
temeluchus
PostPosted: 00:34 - 26 Jul 2009    Post subject: Reply with quote
If you can afford it replace the lot.
PostPosted: 00:53 - 26 Jul 2009    Post subject: Reply with quote
Front Sprocket- Yes
Rear Sprocket - No
Chain - Possibly (might just need a clean and adjustment or might be too worn)
I'd do the lot if the chain is wrecked.
Pat
Mark65
PostPosted: 09:05 - 26 Jul 2009    Post subject: Reply with quote
If you dont want it playing on your mind and it would mine, i would replace all three, better safe than sorry. The rear looks ok but if the chain is screwed and you use it, it may damage the new ones and proove to be false economy.
Mark
PostPosted: 09:34 - 26 Jul 2009    Post subject: Reply with quote
Howling Terror wrote:
Front Sprocket- Yes
Rear Sprocket - No
Pat
Here's an idea for you:
Why not run a brand new chain on one old and one new sprocket. This is a guaranteed way to have to buy a new chain again very soon! Rolling Eyes
To the OP. Just buy a chain and sprocket kit. Don't faff about replacing some parts and not others. Its a false economy.
PostPosted: 11:33 - 26 Jul 2009    Post subject: Reply with quote
Rear sprocket isn't too bad, chain is unknown and the front sprocket is scrap. Possible that someone has put a new chain and rear sprocket on but left the front, in which case a new front sprocket alone might be worthwhile (as a front sprocket is dirt cheap). However if the chain isn't that decent then just put a full set on.
bikedemon99
PostPosted: 23:29 - 26 Jul 2009    Post subject: Reply with quote
Good to see everyone is voting wisely, look after your bike and it will look after you Smile Karma Thumbs Up
Ride safe
PostPosted: 00:15 - 27 Jul 2009    Post subject: Reply with quote
@MarJay yer sarky so n so.. Smile
to my eyes, the few teeth that i see on that rear sprocket look good. . If they were getting abit pointy/hooked then yeah.
Pat
Walloper
PostPosted: 02:12 - 27 Jul 2009    Post subject: Reply with quote
Perchance the reason they never replaced the front sprocket is coz it is a tight as fook.... And they couldnae get the nut off.
Expect a struggle. Smile
I would do the sprocket as long as the chain pitch extension comes up to scratch. If the chain hits the swing arm adjust the rear wheel back to remove play. If there is no adjustment left then the chain may be washed out and need replacment.
The rear sprocket looks well useable though
el_oso
PostPosted: 12:05 - 27 Jul 2009    Post subject: Reply with quote
find a sprocket and chain kit.
wemoto and busters accessories do kits pretty cheap. if you buy a kit usually only an extra couple of quid to replace all three over just a new chain
Duke 390
Car: Jeep Wrangler 4.0L
johnnyfaro
PostPosted: 13:12 - 27 Jul 2009    Post subject: Reply with quote
........and when getting the front cog off is worth seeing if a friendly garage will gun it off. I borrowed a electric nut gun and took mine off straight away where as a BIG breaker bar hadnt budged it.
carlperkins00...
PostPosted: 19:02 - 27 Jul 2009    Post subject: Reply with quote
just get a new set, much easier and safer. Thumbs Up
stoke
PostPosted: 18:27 - 28 Jul 2009    Post subject: Reply with quote
Although the rear looks in good shape I'd personally go for all 3 just to be on the safe side Smile
The last post was made 17 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.55 - MySQL Queries: 15 - Page Size: 86.61 Kb
