| Harold_Shand |
 Harold_Shand World Chat Champion
| Harold_Shand |
| instigator |
 instigator Super Spammer
| Harold_Shand |
 Posted: 19:24 - 02 Aug 2009 Post subject: |
Oooookaaayyy....
...and parts if I was to do it myself?
 ____________________ BCF's 6th favourite poster 2009-2010
Harold_Shand's theory might be the best explanation. |
| instigator |
 Posted: 20:12 - 02 Aug 2009 Post subject: |
For a zr-7s, yes?
C&S between £65-110 depending on what kit you go for. Have a chain riveter? If not, about £40 for one that will do the job but won't be the 'best' tool. Needs a torque wrench with correct sized socket also for the front sprocket. Or even an impact driver for loosening the front sprocket. They can be a reet pain in the arse.
Carb syncing, it's a parallel twin, yes? Gauges can be had for about £20-30 for the most basic kit probably. Try and borrow some, it's not like you need to do it very often.
Valve clearances - Well, budget for a replacement valve cover gasket just incase, but all that is needed outside the most basic of tool kits if feeler gauges. That is, if, they don't need adjusting. If they do, expect £3 a shim and a fair bit more work. Not hard to do so long as you buy a Haynes and understand the process in how to do it.
https://www.zr-7.com/valves1.htm |
| Zenarchy |
 Zenarchy Nova Slayer
| neatbik |
 neatbik World Chat Champion
 Posted: 09:14 - 03 Aug 2009 Post subject: |
We would have done that for £160, plus another hours labour at £35 + price of shims if they needed adjustment.  |
The last post was made 16 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
