| Groove |
 Groove World Chat Champion
 Posted: 21:34 - 04 Aug 2009 Post subject: Car problem - "juddering" at speed? Any ideas? |
Car in question is my ROVER 220 Turbo Coupe.
Problem is:
When you build up speed at anything over 50-60mph the car judders from what seems to be the engine bay. It will start a light judder but the more you build up past 50-60 with shake you almost out of your seat and feels like the engine will fall out! Its also quite loud from in the cabin.
There is also a clunk sound coming from underneath the car when you change gear in any other manner except ultra smooth. Happens in all gears. But the juddering i havnt noticed apart from 4th and 5th althought i havnt really tested the other gears.
Any ideas or tips on what to check to see if i can diagnose my self?
Thanks
Groove ____________________ || Past: 1991 Kawasaki ZXR 250 ~ 2003 Honda CBR 600 F Sport ~ 2004 Kawasaki ZX6R B1H 636 ~ 1999 Yamaha R1 ~ 1999 Kawasaki ZX6R J ~ 2004 Kawasaki ZX6R B1H 636 ~ 1998 Honda VTR1000F Firestorm ~ K1 GSXR 600 Track bike ~ K6 GSXR 1000 ~ 2006 Speed Triple 1050 || Current: 2005 R1 https://www.adrucore.co.uk |
| AngelGrinder |
 AngelGrinder World Chat Champion
| Flip |
 Flip Super Spammer
| Groove |
 Posted: 21:50 - 04 Aug 2009 Post subject: |
| KevTM |
 KevTM World Chat Champion
| Stoo |
 Stoo PoshBoy
| 10 pence Short |
 10 pence Short Crazy Courier
| Groove |
| D O G |
 D O G World Chat Champion
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
 Posted: 08:51 - 05 Aug 2009 Post subject: |
https://www.rovertech.net/
One of the techie nerds on there will more than likely diagnose it whilst mid-doughnut. |
| panrider_uk |
 panrider_uk World Chat Champion
| Groove |
 Posted: 21:37 - 05 Aug 2009 Post subject: |
Engine seems to be sturdy.
Dont get any feedback through steering wheel except when the whole car is shaking which is when it is really bad. Which makes me believe that its not the wheels.
No clunks over bumps or harsh accelerating or braking so would have thought that wipes out engine mount.
Doesnt do it out of gear or when off the throttle and you can hear it clunking somtimes when accelerating which seems to come from under the car.
That help any diagnosis? ____________________ || Past: 1991 Kawasaki ZXR 250 ~ 2003 Honda CBR 600 F Sport ~ 2004 Kawasaki ZX6R B1H 636 ~ 1999 Yamaha R1 ~ 1999 Kawasaki ZX6R J ~ 2004 Kawasaki ZX6R B1H 636 ~ 1998 Honda VTR1000F Firestorm ~ K1 GSXR 600 Track bike ~ K6 GSXR 1000 ~ 2006 Speed Triple 1050 || Current: 2005 R1 https://www.adrucore.co.uk |
| prawny1 |
 prawny1 World Chat Champion
 Posted: 22:08 - 05 Aug 2009 Post subject: |
Worn cv can give you juddering (won't nessererily click on full lock either), that could explain the knocking when changing gear agressivly too as the shaft will whip to take up the slack.
Get the car in the air and give everything a good hard tug to find out if you have any excess play any where.
Another thing to consider would be to check the shocks are not fubar, If you get a bad shock the wheel can start to bounce uncontrolably at speed, I have seen it loads of times going down the motor way, its pretty scary to watch , my brothers old bmw would shake the sunroof control panel off and make his sun visors drop when he went to fast because one of his back shocks had leaked, He finaly got me to change it when he got sick of putting his interior back together whenever he pulled over.  |
| njd27 |
 njd27 Trackday Trickster
| The View Askew |
 The View Askew World Chat Champion
 Posted: 17:28 - 06 Aug 2009 Post subject: |
Had same issue with my vectra, it was the wheels, and it started to be noticeable at 50-60mph exactly the same.
I had taken wheels from another car, so the wear was off for the vec, took a while to bed the tyres in to the vecs pattern then it stopped.
Has it had any change to the wheels in any way? are they alloys? If they are, when wheels are balanced, they are weighted, it is possible for one of these weights to come off.
If they are the standard wheels, and nothing's been changed, try rotating the spare wheel round all 4 to see if it suddenly goes away once a wheel is removed, and while you do so, look for a rectangular clean patch on the inside of the dish for an alloy, or clipped to the rim on a steely. ____________________ "Do what you always did, get what you always got" |
| Groove |
 Posted: 18:43 - 07 Aug 2009 Post subject: |
No change in the wheels apart from a nasty pot hole the missus hit when it started.
The juddering stops when you are just rolling along in neutral at speed or when you let off the accelorator could this still be the wheels? If so then i shall try to get them checked out this morning.
The donking noise from under the car is a bit suspicious though when lifting the clutch up?
Cant get under the car as its too low and dont have a jack
Seems to be getting worse  ____________________ || Past: 1991 Kawasaki ZXR 250 ~ 2003 Honda CBR 600 F Sport ~ 2004 Kawasaki ZX6R B1H 636 ~ 1999 Yamaha R1 ~ 1999 Kawasaki ZX6R J ~ 2004 Kawasaki ZX6R B1H 636 ~ 1998 Honda VTR1000F Firestorm ~ K1 GSXR 600 Track bike ~ K6 GSXR 1000 ~ 2006 Speed Triple 1050 || Current: 2005 R1 https://www.adrucore.co.uk |
 Posted: 18:55 - 07 Aug 2009 Post subject: |
Check the wheelnuts! If they are ok jack the wheels up and wobble each one to check the bearings. Also if the driveshafts have weights on them like some cars do - check them.
If they are ok then try this:
Lift the bonnet and get someone in the driver seat. Handbrake on, 1st gear and carefully try to pull away whilst you watch the engine bay from outside. If you have a busted engine mount you'll either hear the donk or see the engine lurch markedly. Try not to get yourself run over doing this  ____________________ a.k.a 'Geri'
| Groove |
| D O G |
| Groove |
 Posted: 20:50 - 17 Aug 2009 Post subject: |
Ok, well had a look underneath and one drive shaft is bent. The other is on its way out so both will be getting changed. Simple?
No.
One drive shaft (the bent one) was changed "for a longer rover one as the orignal kept popping out after the gearbox got taken out".
How do i found out what this new one is? Apart from measure it and hope...
I could change it back to the original along with the hub thats also been changed and hope for the best, how risky could that be though? Dont want the argo of keep getting towed home!
The previous owner believed the "popping out" to be a common problem. If it is common, has anyone had it before and is there a particular drive shaft that gets put it its place?
Thanks for any help!  ____________________ || Past: 1991 Kawasaki ZXR 250 ~ 2003 Honda CBR 600 F Sport ~ 2004 Kawasaki ZX6R B1H 636 ~ 1999 Yamaha R1 ~ 1999 Kawasaki ZX6R J ~ 2004 Kawasaki ZX6R B1H 636 ~ 1998 Honda VTR1000F Firestorm ~ K1 GSXR 600 Track bike ~ K6 GSXR 1000 ~ 2006 Speed Triple 1050 || Current: 2005 R1 https://www.adrucore.co.uk |
| Groove |
 Posted: 21:16 - 17 Aug 2009 Post subject: |
No picture, its bent on the shaft itself and is visible when you turn the wheel.
Rubbers have split either end and will be drying up so im told by a mate (no oil there), could replace them i believe but then this one seems to not run quite true neither! I blame shite road suffaces around here! (its rather low, hit a little bump and you know about it!)
Yes, thats what we think, not been put back right. But then why go through all the bother of sourcing a different drive shaft and hub to accomadate said drive shaft if the problem is harder to fix than that!
The one that is nicely bent is the one that is the "longer" one. ____________________ || Past: 1991 Kawasaki ZXR 250 ~ 2003 Honda CBR 600 F Sport ~ 2004 Kawasaki ZX6R B1H 636 ~ 1999 Yamaha R1 ~ 1999 Kawasaki ZX6R J ~ 2004 Kawasaki ZX6R B1H 636 ~ 1998 Honda VTR1000F Firestorm ~ K1 GSXR 600 Track bike ~ K6 GSXR 1000 ~ 2006 Speed Triple 1050 || Current: 2005 R1 https://www.adrucore.co.uk |
| chrisw |
 chrisw World Chat Champion
The last post was made 17 years, 78 days ago. Instead of replying here, would creating a new thread be more useful? |
