hissing noise when i try and start
ash8865
PostPosted: 13:11 - 07 Aug 2009    Post subject: hissing noise when i try and start Reply with quote
suzuki gsf 600 1997. there is a hissing noise when i try and start. what could be the problem?? iv done a full oil and filter change and also plugs can anyone help
the grim reaper
PostPosted: 13:18 - 07 Aug 2009    Post subject: Reply with quote
loads more detail needed. Is the engine turning over at all? Is the hissing more like a clicking noise? First instinct says flat battery but without further detail it's impossible to say.
Cheers
Grim
Frost
PostPosted: 14:54 - 07 Aug 2009    Post subject: Reply with quote
If all you get is a hiss, with no starter motor noise or engine rotation, then it's either an electrical short, or far more likely a completely dead battery.
ash8865
PostPosted: 11:22 - 09 Aug 2009    Post subject: Reply with quote
it is trying to start just as its turning over its making the hissing noise iv had the battery out and charged just in case it was that but the problem still persists
Blue_SV650S
PostPosted: 11:46 - 09 Aug 2009    Post subject: Reply with quote
Have you knocked the carbs or airfilter off when swapping the plugs? did you go in from the front or under the tank?
And finally are you sure all the plugs are 'home'??
The last post was made 16 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 42.21 Kb
