JAMMED KICKSTARTER
stirlinggaz
PostPosted: 10:00 - 09 Aug 2009    Post subject: JAMMED KICKSTARTER Reply with quote
Hi all,
im swapping engines on my mtx.
the transplant engine looks all ok & i've sorted the top end & the gears look ok. (its changing gear anyway, lol)
but stupidly i never thought to check the kickstart & tbh, i wouldnt have known what to look for anyway!
so i have stuck the engine back in the bike & bolted on the kick start lever.
but when i go to kick it : NOTHING!!
it wont even move, not budging a bit.
seems to be stuck solid.
any ideas?
does this mean the crankcases need to be split?
i presume i'll have to take the engine back out the bike, right?
just not sure what im supposed to be looking for & where to start!
anyone offer any ideas? (apart from chucking it in a skip, which i think i may have to do anyway,lol)
cheers,
GAZ
PostPosted: 10:23 - 09 Aug 2009    Post subject: Reply with quote
Is the engine seized?
stirlinggaz
PostPosted: 11:10 - 09 Aug 2009    Post subject: Reply with quote
Hi,
when i had the engine in the shed, i could turn the flywheel by hand.
& the top end moved up & down as it should.
thats as much as i checked. (as well as checking the clutch arm & whether it changed gear)
cheers,
GAZ
PostPosted: 11:31 - 09 Aug 2009    Post subject: Reply with quote
I've only got experience with Yamaha kickstarters so it could be different with your Honda, but the mechanism was always just behind the right clutch cover and so you shouldn't have to split the crank cases.
tshort2007
PostPosted: 13:51 - 09 Aug 2009    Post subject: Reply with quote
had summat similar on a ns125. The mechanism was behind the R cover, and we put the one way cam on wrong. it was set at rest against the stop that prevents overkick. turned it round 3/4, rebuilt and it was fine!!
The last post was made 16 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 43.41 Kb
