Fuse question
Graprilia
PostPosted: 14:54 - 09 Aug 2009    Post subject: Fuse question Reply with quote
For a while now since i had last took my bike into the garage the indicators have not been working so today i took the body work off to locate the fuse box to find the lid not closed down so i think water may have corrided it or something.
Anyway it is the blue fuse which is knackered if i replaced it would this sort the indicators out? Also what is the size of the blue fuse?And were can i buy a replacement?
Thanks
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
Frost
PostPosted: 15:31 - 09 Aug 2009    Post subject: Reply with quote
Pretty sure a blue is a 15A fuse. It should be written on it anyway. If the fuse has blown, that will be stopping your indicators from working, but something made it blow, so its going to keep happening untill you find the real problem. If it's not blown then corrosion might be the cause. Scrape the crap off everything and replace the fuse.
Graprilia
PostPosted: 15:58 - 09 Aug 2009    Post subject: Reply with quote
cheers , i have just cleaned it and but a new one in but still no joy , any other ideas as to what it could be the mechanic was supposed of put a new relay in so it shouldnt be that.
tshort2007
PostPosted: 16:34 - 09 Aug 2009    Post subject: Reply with quote
check he secured it! you got a multimeter?
Graprilia
PostPosted: 16:55 - 09 Aug 2009    Post subject: Reply with quote
no i havent got one
Blue_SV650S
PostPosted: 17:05 - 09 Aug 2009    Post subject: Reply with quote
Do the indicators come on but not flash or not come on at all?
Frost
PostPosted: 17:08 - 09 Aug 2009    Post subject: Reply with quote
Do none of the indicators work at all?
Provided you have all the fuses in place, not blown and contacting properly it can only be the relay. You should hear a ticking when the indicators are on. If you dont chances are there isn't a relay, it isn't plugged in, or its fucked.
Graprilia
PostPosted: 17:16 - 09 Aug 2009    Post subject: Reply with quote
On the day i got the bike back the indicators worked and i could hear the clicking.
The next day i started the bike up to go to work and none of the indicators worked and the clicking sound had disappeared.
tshort2007
PostPosted: 21:18 - 10 Aug 2009    Post subject: Reply with quote
sounds like a loose wire. I assume its both sides not working?
Do the other butons on the same switch work?
Can you hear a buzzing or clicking when you try the indicators
Do the rest of your lights work?
Graprilia
PostPosted: 22:24 - 10 Aug 2009    Post subject: Reply with quote
both sides dont work.
The other buttons work on that side.
There is no clicking or buzzing anymore.
The rest of the lights work fine.
Frost
PostPosted: 23:15 - 10 Aug 2009    Post subject: Reply with quote
Might be a shitty cheap relay. I had one that lasted for a single flash last month. Might be a loose wire or something shorting blowing the relay. It's really hard to fault find without a multimeter and a bit of expirence.
Finglonga
PostPosted: 12:48 - 11 Aug 2009    Post subject: Re: Fuse question Reply with quote
Thanks
Check all connections including the earth as any bad connection may stop just enough current getting through to make them work.
Andy Sez....
F.Y.Y.F.F.
bradh511
PostPosted: 21:34 - 11 Aug 2009    Post subject: Reply with quote
i had a chinese 50cc import blowing relays all the time until i put a honda one on i would think its the relay clicking sounds like relay mine was doing that for £6 it worth a try
p.s that import is no more hehe :D
The last post was made 16 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 75.77 Kb
