Car question sorry! 323 feels like its going to stall
wizzzard
PostPosted: 14:18 - 07 Aug 2009    Post subject: Car question sorry! 323 feels like its going to stall Reply with quote
I went to collect one of my bikes from the bosses garage last night and I drove there without a problem. My wife drove back and within half a mile the car had started chugging when coming up to lights. I caught up and followed and it seems to run fine at speed but whenever she came to a stop or slowed down to a crawl the car would shudder and chug like it was about to stall although it doesnt actually stall.
I know the obvious answer is not to slow for anything Smile
The car is a 96 mazda 323f and I was wondering if anyone could give me a few pointers on where to begin looking when I get in this evening.
Finglonga
PostPosted: 15:13 - 07 Aug 2009    Post subject: Reply with quote
Idle control valve dirty? How is it on tickover?
Andy Sez....
F.Y.Y.F.F.
wizzzard
PostPosted: 15:38 - 07 Aug 2009    Post subject: Reply with quote
It's hunting on tickover. Sounds like the exhust is blowing when you pull away but that vanishes at above about twenty.
Thanks Finglonga. Will check the idle control and I'm going to check there are no perished pipes.
Phoenix
Twisted Firestarter
PostPosted: 16:40 - 07 Aug 2009    Post subject: Reply with quote
Blocked injector(s)?
wizzzard
PostPosted: 17:00 - 07 Aug 2009    Post subject: Reply with quote
Thanks Phoenix I've been looking around on the net for ideas and hadn't come across that one. It does sound like a possibility but the car itself isn't worth the price of fixing that so if it is the car goes in the bin.
Now to find out how to test for a blocked injector Smile
Burnzy1989
PostPosted: 17:06 - 07 Aug 2009    Post subject: Reply with quote
where about is it blowing and is the engine manegmant light on ?
wizzzard
PostPosted: 17:21 - 07 Aug 2009    Post subject: Reply with quote
No management light on and the blowing sound is coming from the end of the exhaust no holes along it or anything but it just sounds just like it would do from a hole along the pipe.
tshort2007
PostPosted: 11:26 - 08 Aug 2009    Post subject: Reply with quote
had a similar problem on a rs2000, if the idle is hunting, the valve appears to be working. Most likely a air leak in the inlet manifold. with the engne idlng, spray WD40 around the inlet manifold everywhere from the airflow sensor to the block. the blowing sound is more likely a sound similar to an induction kit on performance cars. a blowin exhaust sounds wore the faster you rev, an intake leak gets quieter, as the ratio of air thats leaking lowers compared to the metered air.
PS the rs2000 had a vacumn hose that had fell off!! took us bout 4 hours tofind it!
wizzzard
PostPosted: 12:44 - 10 Aug 2009    Post subject: Reply with quote
It turns out it was indeed the idle control valve, thanks again Finglonga.
Tried cleaning it to no avail so I've unplugged it and it now idles without stalling but has brought a flashing hold light up on the dash. The car seems to drive absolutely fine again now with the only exeption being that it seems to stay in gear longer before changing up ( its an automatic so sounds like im reving the nuts off it at low speeds ).
The car itself isn't worth getting a new part for and ill just get a new one at the end of the month but was wondering if this one is ok for my wife to drive in the mean time.
PostPosted: 18:53 - 10 Aug 2009    Post subject: Reply with quote
What did you try cleaning it with?
wizzzard
PostPosted: 22:46 - 10 Aug 2009    Post subject: Reply with quote
I had some Maplins electrical solvent cleaner around so I tried that. I was a little unsure how harsh a product to use.
PostPosted: 22:49 - 10 Aug 2009    Post subject: Reply with quote
Carb cleaner is probably the best thing to use.
wizzzard
PostPosted: 22:52 - 10 Aug 2009    Post subject: Reply with quote
Thanks Keith I'll give it another try with carb cleaner when I get in from work tomorrow. Thumbs Up
swanny
PostPosted: 22:56 - 10 Aug 2009    Post subject: Reply with quote
get some engine cleaner and shove it in your tank ( not redex.. proper stuff.. ).. take the car for a nice long drive and should see a marked improvement..
if im right the mazda's have the same engines as the fords didn before zetec and they had the same problem..
it stems from using cheaper fuel like supermarket fuel.. once its unbloked every 4th fill up use the expensive petrol and should be reet.
M SWANNY.. see a sig !
wizzzard
PostPosted: 23:01 - 10 Aug 2009    Post subject: Reply with quote
Thanks for the advice swanny. My wife had filled it up just that afternoon at the local supermarket.
So carb and engine cleaner on tomorrows shopping list Karma
Raffles
PostPosted: 22:10 - 11 Aug 2009    Post subject: Reply with quote
I bought into the 'expensive petrol' con some years ago and it cost me plenty. I was seduced into using 'Formula Shell', a petrol that was going to clean my engine, improve my fuel economy and enable me to compete with the world's best racing drivers. I didn't notice any of those benefits. What I did notice was a knackered engine caused by chronic pre-ignition and I have never bought Shell fuels since and I never will again. Give me the cheap shit any day!
The last post was made 16 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 91.58 Kb
