My other Pit bike
binge
Emo Kiddy
PostPosted: 20:53 - 11 Aug 2009    Post subject: My other Pit bike Reply with quote
While my TZR pit bikes been off the road getting rebuilt, I decided to take on another little project to hoon around my woods on.
It's based as close to a CRF50 as possible. Running a 110cc Semi auto engine, With genuine Honda CRF50 stator and flywheel. Honda engine cover. I was quite proud of myself. It's the first 4t bike engine I've done a full top end rebuild on and had it running after. It runs superb!
It's fast enough for off road. There is a little MX track in my local woods. Its about 500 meters from my house. If I go out of my garden into the woods. Across a foot bridge into some more woods. The track is there.
It's situated between a Motorway, And a main road. So I wont be getting hassled there. I've spoke to a local guy who built the track 5 years ago, He takes his boys there every weekend. And he rides it himself, He's been riding there for 5 years and never been bothered by the law once.
https://img.photobucket.com/albums/v358/binge/Photo0678.jpg
https://img.photobucket.com/albums/v358/binge/Photo0674.jpg
https://img.photobucket.com/albums/v358/binge/Photo0671.jpg
Throttle
PostPosted: 18:19 - 12 Aug 2009    Post subject: Reply with quote
Very nice Thumbs Up
You should get this on the road! Always liked the look of these.
I noticed that their is a little off-road track near Blackpool Airport the other day (we have a flat nearby). I am tempted to try a bit off-roading but I am saving for a Monkey at the moment so can't afford a bike JUST for that.
May give it a shot on a Monkey though, see what that is like!
binge
Emo Kiddy
PostPosted: 20:24 - 12 Aug 2009    Post subject: Reply with quote
The monkey bike frames are more or less the same as the pit bike frames.
Fit some longer forks, Off road tyres, and some big bars, and it will practically be a pit bike with a different tank and no plastics.
And I plan to get the CRF on the road! Very Happy
Throttle
PostPosted: 20:48 - 12 Aug 2009    Post subject: Reply with quote
That will be an interesting thread if you get the CRF on the road!
Should bring it down to a run if you do!
Will you be fitting lights etc? Or just running it on a daytime MOT?
binge
Emo Kiddy
PostPosted: 20:56 - 12 Aug 2009    Post subject: Reply with quote
Because I already have my TZR125 powered Road legal pit bike with lights. I will probably just run the CRF rep on a Daytime only.
So That's Horn and Speedo. Laughing
Throttle
PostPosted: 21:03 - 12 Aug 2009    Post subject: Reply with quote
Lights are for losers Wink
binge
Emo Kiddy
PostPosted: 23:14 - 16 Aug 2009    Post subject: Reply with quote
Couple of updates.
Fitted some Honda CRF50 forks, and Honda CRF50 Shock.
So its sitting at the right ride height now.
Frame is still the Chinker. Once I swap it over to the CRF50 frame, Then the rake will be right, Forks will be more upright. And the front end will sit higher, where it should be.
Still got fork guards to fit, And a caliper mount to make up so I can run a disk up front rather than drum.
And got to fit some black BMX bars.
Engine is still going super strong! It's such a tight, Punchy engine. Well chuffed. It starts first kick every time.
https://img.photobucket.com/albums/v358/binge/Photo0703.jpg
https://img.photobucket.com/albums/v358/binge/Photo0704.jpg
https://img.photobucket.com/albums/v358/binge/Photo0706.jpg
binge
Emo Kiddy
PostPosted: 22:48 - 18 Aug 2009    Post subject: Reply with quote
Fab'd up a Caliper mount to run a disk up front rather than the CRF50 drum.
Still only a prototype. need to cut a proper one out as its a bit thin around the bolt mountings.
https://img.photobucket.com/albums/v358/binge/Photo0710.jpg
https://img.photobucket.com/albums/v358/binge/Photo0712.jpg
Throttle
PostPosted: 19:14 - 19 Aug 2009    Post subject: Reply with quote
Drooling
How long till it's finished?
binge
Emo Kiddy
PostPosted: 22:51 - 19 Aug 2009    Post subject: Reply with quote
Not too sure.
My "new" frame arrived today. It's a proper CRF50 frame, So its dinky. Much shorter than the frame I've currently got.
Unfortunately its a bit old so it needs a re-paint. It's sat at work at the moment. I spent a few hours sanding it down today. Will give it a coat of paint tomorrow.
It's getting painted silver.
Tomorrow night I'll be cutting out a new caliper bracket, Alot neater and slightly bigger around the edges so theres more metal around the bolt holes.
Other than that, Waiting on some odyssey civilian BMX bars and new risers. Got to rig up the rear hand brake and remove the foot pedal.
Then technically its finished.
Long term I want to remove the gold from the rims, and have them chrome instead (Stock CRF50 style).
Drop a couple of teeth on the rear sprocket. My sprocket and wheel ratio is designed for a 50cc Honda engine. I am running a 110cc engine, So its constantly spinning up, and topping out at less than 30mph. Laughing
binge
Emo Kiddy
PostPosted: 18:29 - 22 Aug 2009    Post subject: Reply with quote
New frame fitted! Smile
Also fitted BMX bars, And I'm waiting on a new Top Yoke/Clamp designed for Adults. It will run my BMX bars perfectly too.
Frame is being reinforced next week and I'm looking at Scooter rear brake cables so I can run the rear drum brake from a clutch lever on the left of the bars.
Front caliper is mounted up properly, Bled and functions superbly. Cool
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0729.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0730.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0723.jpg
Digitalize
PostPosted: 22:35 - 22 Aug 2009    Post subject: Reply with quote
Get some Gold Bars, the previous ones colour looked better, but i imagine the BMX Bars are easier for riding.
binge
Emo Kiddy
PostPosted: 00:17 - 24 Aug 2009    Post subject: Reply with quote
I'm trying to shake off all the gold bits. I'm spraying the caliper black to try and make the gold wheels look better.
The gold makes it look proper Chinkey. Laughing
BMX bars are top for riding.
Once I get the Red Barron Billet Top Clamp Kit and rear hand brake kit. It will infact be like riding a fast BMX. Very Happy
binge
Emo Kiddy
PostPosted: 20:30 - 25 Aug 2009    Post subject: Reply with quote
Got my Red Baron Billet top clamp today, Fitted it up. MUCH better! Razz
I've also ordered a Rectifier so I can power a brake light and a Horn.
Looking into getting a Monkey bike VIN and V5 so I can get this thing on the road! Very Happy
Bits to come:
BBR Motorsport Bar Pad
Rear brake cable for hand brake
Rectifier
Fork Guards
And its game on!
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0745.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0743.jpg
Throttle
PostPosted: 00:01 - 26 Aug 2009    Post subject: Reply with quote
Looking really good pal,
Love that Billet clamp, little touches like that really finish a bike off!
I agree about the gold. Always reminds me of American cars.
Be smashing if you get it on the road!
I feel like a stalker being the only one posting on here frequently Shifty
JakeyR
PostPosted: 01:26 - 26 Aug 2009    Post subject: Reply with quote
Wicked man, TZR plate on the CRF = made of win! Thumbs Up rozzers wont know the difference!
Mystery
PostPosted: 12:41 - 26 Aug 2009    Post subject: Reply with quote
nice, what about red wheels and black cals? might look ok with the red fairings as well
Throttle
PostPosted: 15:26 - 26 Aug 2009    Post subject: Reply with quote
Ever thought of entering your pit bikes into the competitions they have on Planet Minis?
binge
Emo Kiddy
PostPosted: 21:43 - 26 Aug 2009    Post subject: Reply with quote
As its only a Replica, And not a Gen Honda. It's not liked very much anywhere other than on the Pit Bike Club Forum.
I was thinking about entering the TZR Pit bike into Britains got Biking talent. But Never got round to it.
But thats illigal Shifty
The TZR pit isnt even the original frame anyway.
Trying to keep it looking as stock as possible, But with little trick bits like the billet top clamp.
I'm gonna do the caliper Black for now. I'd like some new wheels eventually. Either Black or Silver rims. Not a fan of coloured wheels really. The gold is bad enough! Laughing
Little update...
I got another set of forks today. I paid £22 posted for them. The seller said they have 1 bent leg and 1 decent leg, So I can use one of the legs and any other parts to fix up my current forks.
Anyway, I stripped them down today at work. Soaked everything in WD40 to clean it all.
As I inspected them, The fork legs looked quite different. Rather than the CRF50 fork legs im used to seeing, Which look like they have been hammered flat at the bottom and a hole drilled in them for the axle.
They had a proper welded base on them.
As I pulled them apart, I noticed that they had the Fast 50's Heavy duty Fork leg bushings fitted, Which were solid as anything!
And as I pulled the leg right out of the forks, I noticed all the metal bushes were Gold, And made from Billet!
When I got home, I also noticed that the legs are actually +1 legs.
But the so called "bent" leg, was bent so little, you cant notice it by eye. Rolling it on a glass table shows its about 1mm bent. Which is nothing. Cool
So I'm WELL chuffed! Along with my Red Baron Top clamp. I've got like £200 worth of forks on my Fiddy now! Smile
I spent this evening assembling the forks in my garage with fresh grease. Re-spaced the front wheel as the +1 legs have different bottoms.
I had to trim my caliper mount slightly, But it fits better now. The flat cut edge on the bottom of the new fork legs acts as a stopper to prevent the caliper from moving back when I pull the brake when rolling the bike backwards.
Rear shock is a tad spongey now compared to the forks. But nothing a Heavy Duty spring wont sort out.
New and old fork leg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0747.jpg
New and old fork internals. Bushing and spring.
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0748.jpg
Geo Check. Notice the pegs are still tilted forwards. I think its the cheap peg bar.
Will have to get a Fast 50's one to mount the pegs properly.
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0749.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0750.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0751.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0754.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0755.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0756.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0757.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0758.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0759.jpg
binge
Emo Kiddy
PostPosted: 10:55 - 27 Aug 2009    Post subject: Reply with quote
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0766.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0765.jpg
https://i902.photobucket.com/albums/ac227/pitbikeben/Photo0764.jpg
Throttle
PostPosted: 11:21 - 27 Aug 2009    Post subject: Reply with quote
Day off?
Lovely shots! Makes me want to try some off roading on a pit bike.
I am beginning to hate you more and more everyday Binge Laughing
binge
Emo Kiddy
PostPosted: 11:28 - 27 Aug 2009    Post subject: Reply with quote
Yea got the day off work today. So Decided to go for a little spin through the woods! Cool
It rides really nice now. Just need to sort the shock out as the arse is a big saggy.
Throttle
PostPosted: 11:33 - 27 Aug 2009    Post subject: Reply with quote
It must be awesome to have that woods at the back of your house!
Is the rear shock the last big step? Or are you waiting on more parts?
How many pit bikes do you own now then?
I shouldn't have seen sexual connotation's in saggy arse but I did.
binge
Emo Kiddy
PostPosted: 11:46 - 27 Aug 2009    Post subject: Reply with quote
Heavy Duty rear shock will sort out the handling. Probably the next big step for the time being.
I should get my bits today or tomorrow. I've got a Moped rear brake cable on its way, So I can run the rear drum brake from the lever on the bars. (Its semi auto so no clutch).
Got a BBR Motorsport bar pad on its way.
Eventually I want chrome or black wheels, But thats not important at the moment.
I've just bought some new tyres. Slightly more aggressive tread as the tyres I have currently dont grip at all when its wet.
I've also just bought a new side stand as mines just a cut down Chinese one.
I've also got a reg-Rec in the post so I can run a Horn and Brake light. Cool
oJaXo
PostPosted: 12:27 - 02 Sep 2009    Post subject: Reply with quote
looks sweet, love to do my own lil project like this if i had the money Laughing
The last post was made 17 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 137.09 Kb
