pegout speedfight 2 2 stroke air cooled 56 plate - help.
jameswallace
PostPosted: 13:13 - 11 Aug 2009    Post subject: pegout speedfight 2 2 stroke air cooled 56 plate - help. Reply with quote
Hi I have got a pegout speed fight 2, 2 stroke air colled 50cc 56 plate, and it idles absolutly fine, and revs its nuts off with out the air box on the carb, but as soon as its on, it only idles, and then if reved dies / stutters,
It had a new plug after this problem started, and it was just as bad. My friend recons it is the auto choke, as we have had the carb of many times to clean the jet out, and we recon its hanged by the wires, and has buggered
Auto choke up.
Would like to know if anyone could help me out.
Or has had a similar problem. I've oredered a new carb, so fingers crossed but would like some one else opinio
n.e
Thanks a lot in advance Smile
TJenkos
PostPosted: 15:48 - 11 Aug 2009    Post subject: Reply with quote
It indicates that it wants more air, have you tried adjusting the air/fuel ratio?
Passed CBT: 21/05/2006 Passed A2 Test: 17/05/2008
Previous Bike: '99 Peugeot Speedfight, '54 Jetforce TSDI, '03 Yamaha R6
Current Bike: '58 Yamaha R6 & '89 Honda VFR400R NC30 SP2
PostPosted: 16:09 - 11 Aug 2009    Post subject: Reply with quote
Or less fuel.
jameswallace
PostPosted: 09:49 - 12 Aug 2009    Post subject: Reply with quote
Well the thing is all that's neverbeen touched. So it has no reasom
To go wrong. The autoc choke wire has been holding the weight of the carbwhen
It was of, so possibly could be that.!
Thanks for your reply anywway Smile
clancy
PostPosted: 09:52 - 12 Aug 2009    Post subject: Reply with quote
sell it
jameswallace
PostPosted: 19:49 - 15 Aug 2009    Post subject: Reply with quote
i dont want to sell it because its done loads of miles, and never missed a beat. i have tryed out another carb, and its exact same. it reves its nutes off without an air box and has no power without one....
need help urgently, anyone had a similar prob?
thanks in advance
cheryl_matthews
PostPosted: 18:46 - 01 Sep 2009    Post subject: speedfight 2 not starting all the time everytime!!! Reply with quote
thanks in advance
hi i have a problem with my speedfight 2 also, in the mornings i can start it up and ride to work but after work it will take me a pretty long time to start it up with the electric start (kick is also the same) and i look like a complete idiot, my dad has had my carb off and has cleaned it out and all. he recons it's my choke that could be messing up, i dunno if you can relate to my query if you can help me id be more then greatful sorry i can't quite help you out with you issue but does your's seem to be the same????
reguards cheryl!!! Very Happy
jameswallace
PostPosted: 11:23 - 02 Sep 2009    Post subject: Reply with quote
Have you had the carb of and cleaned it (can't remeber if u mentioned that or not)
And also have you checked the auto choke is functoning correctly? Might be permanantly
Shut. I have fixed my engine issue's, it was a internal problem, had to replace half the engine, I supsext
That it is a carb issue, either choke or a jet blocked. It could be the main jet as there is a jet beneath the jet
Or it could be the idle jet that is blocked. Hope this helps.
cheryl_matthews
PostPosted: 23:42 - 02 Sep 2009    Post subject: Reply with quote
hi thank you for getting back to me im glad you have sorted your bike out! yeah my dad cleaned out the carb and stuff but i shall let my dad know what you have said as most of that didn't make sense to me Laughing but how can you check if the auto choke is functioning correctly?
tonyts50 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
jameswallace
PostPosted: 16:47 - 17 Dec 2009    Post subject: Reply with quote
i have pm'ed you, with some ideas, but i also supect like mine i also had an issue with the baffler, take it out, put up with the whistling!
EnergyInducti...
PostPosted: 20:10 - 18 Dec 2009    Post subject: Reply with quote
Usual suspects:
1. Float set too high
2. Reed valves not opening and closing properely with increased load (Unlikely, But still had it happen)
3. Main jet too high, but by the sound of it, it was fine before with the same jet
4. Air filter clogged
5. Exhaust coked up to high hell
Either way, PM me if you need further help, But check all of these first =)
Riding: Yamaha RXS100
Aiming for : RD350 + Test
Dream bike: Suzi RG500 Gamma
andys675
PostPosted: 21:16 - 18 Dec 2009    Post subject: Reply with quote
take the auto choke off the carb when stone cold, , measure the length the brass bit is sticking out by, then take the wires of the auto choke and directly put one to the positive side and one to the negative side of the battery, after 10 mins the brass bit should be sticking out considerably more than before you started, about 10mm more, if not its knackered
basically this is all that happens when you turn the ignition on, power goes to the electric choke making it slowly close the chamber in the carb until it stops, there you have it, stone cold valve open, warm it up and it closes choke off. simple enough?
There is a gap of 340 days between these two posts...
Dane123UK
PostPosted: 18:21 - 24 Nov 2010    Post subject: Reply with quote
Ive just bought a speedfight 2 and my engine blew, got a new engine, it all fits and works. ive had it back a day and alf and already its like its taking the last bits of petrol ad stutters reving like mad, ive changed the spark plug to see if it was that and nothings changed, can you help me out? its the same sorta problom to this tbh.
HD
PostPosted: 19:53 - 24 Nov 2010    Post subject: Reply with quote
Do what they did then? Clean the carb and check the auto choke? A mate had this problem with his not long ago.
Oh and:
https://www.contractortalk.com/attachments/f16/22142d1250251071-sub-contractor-lower-insurance-than-me-old_thread.jpg
Dane123UK
PostPosted: 21:47 - 30 Nov 2010    Post subject: Reply with quote
HD wrote:
Do what they did then? Clean the carb and check the auto choke? A mate had this problem with his not long ago.]
I did, its all okay, went on it again today and it's not doing it as much but its still doing it, some said about the spark plug?, so i swapped it and its not that. any help? :/
HD
PostPosted: 21:58 - 30 Nov 2010    Post subject: Reply with quote
Looked at the fuel lines/filter(s) to see if it/they are blocked?
Dane123UK
PostPosted: 22:09 - 30 Nov 2010    Post subject: Reply with quote
I aint checked them, im not good with bikes. when you say filter, asin air filter?, orrr?, explain what i should do and how i should do it, thanks.
HD
PostPosted: 22:31 - 30 Nov 2010    Post subject: Reply with quote
Im not great myself.
But yes, air filter may be a place to start; i didn't initially mean that Laughing
Then look at your fuel lines. See if they are blocked. There should be one that draws air and one the draws fuel. This is why when you disconnect your fuel tank it doesn't drip everywhere becaus ethe fuel draws the air: hence vacuum pump.
Not sure if yours is the same but thats what its like on my bike.
The fuel filter on mine is inside the tank on the end of the fuel hose. So get ready to empty your fuel into something (or ditch it because it maybe dodgy fuel anyway that is causing the problem) and then see what the filter looks like. Basically, if it is the same as my bike, you just undo a jubilee clip on the pump and the rest comes off. It isn't very wide and has little filters on it. If these are blocked then you can either clean them or buy new ones.
As with most of my posts, I may not be right so its best to listen to people who 100% know what they are on about.
HTH Thumbs Up
Dane123UK
PostPosted: 22:51 - 30 Nov 2010    Post subject: Reply with quote
HTH Thumbs Up
Cheers mate Smile. looks like ill need some tools Wink haha, i was warned 2stokes always fuck up...if i fix it and it happens again, im selling it and get a better ped, or wait till im 17 for a DT 125 Razz, thanks Smile
Dane123UK
PostPosted: 23:03 - 30 Nov 2010    Post subject: Reply with quote
Ps, im new to this, how do you know if someone has replied? :S
HD
PostPosted: 23:12 - 30 Nov 2010    Post subject: Reply with quote
Either go to the 'search BCF' bit and type in your name in the author bit to see all posts that you have made. Any new replies will have a little yellow/orange icon beside it with an arrow. Just click on it and it will take you to the latest post that you haven't read.
Alternatively, you can go to the corresponding forum (this one is workshop) and then find your thread. All threads that you have commented on will have a little + beside the title. If it has had a new post on it, it will again have this little symbol beside it.
Head to the New Bikers bit and introduce yourself.
And welcome to BCF Thumbs Up
The last post was made 15 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 116.73 Kb
