There is oil in my air box!
Blunet600
PostPosted: 10:06 - 14 Aug 2009    Post subject: There is oil in my air box! Reply with quote
I found oil in my air box yesterday ( i ride a hornet 600 04 model), so i cleaned it out with a cloth (as much as i could) then emptied some oil out of my engine as there was a little too much in.
What damage has or could this have caused to my bike?
Im all worried now that the bike is going to get problems.
Cheers.
Honda - Power of Dreams - NSR 125R - Hornet 600
demoNSR
PostPosted: 10:37 - 14 Aug 2009    Post subject: Reply with quote
What type of air filter do you have, is it a sponge type, or the paper type?
Reason i'm asking is because the NSR has a sponge type filter, and when you clean it, you have to soak it in oil before you put it back in. Obviously you would squeeze out the excess first, otherwise you would choke the engine.
How much oil was in your airbox?
PostPosted: 11:02 - 14 Aug 2009    Post subject: Reply with quote
Don't worry too much about it. That's where your crank breather empties, and since you overfilled it with oil, it blew the excess out of the crank breather.
Just double check you don't get more.
Blunet600
PostPosted: 15:09 - 14 Aug 2009    Post subject: Reply with quote
There wasnt alot, it was around and dripping down the sides of the box, but no puddles inside it. Its a cylinder shape, not sponge.
My mate said its just the breather hose putting it in there, will i need to clean out the breather hose?
cheers.
Blue_SV650S
PostPosted: 16:59 - 14 Aug 2009    Post subject: Reply with quote
cheers.
No, it is perfectly normal for all this to be happening.
Its just oil 'mist' collecting over time and forming into a smear layer. Even with 100% correct oil level, it will happen!! If yours was a smidge over then its very unlikely any harm will have been done past or long term.
Seriously, don't worry about it.
Blunet600
PostPosted: 20:18 - 14 Aug 2009    Post subject: Reply with quote
A smidge. . . it was above the top line of the dipstick... just before it rounds off.
PostPosted: 09:59 - 15 Aug 2009    Post subject: Reply with quote
When you measure the level you're not screwing the dipstick in are you?
Blunet600
PostPosted: 22:20 - 15 Aug 2009    Post subject: Reply with quote
no. I put in without screwing it down.
temeluchus
PostPosted: 23:03 - 15 Aug 2009    Post subject: Reply with quote
as ham said, normal if the oil level is a little high or youve been giving it the berries Wink
The last post was made 16 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 64.92 Kb
