Where to order chain and sprockets?
Dr Nick
PostPosted: 16:40 - 12 Jun 2004    Post subject: Where to order chain and sprockets? Reply with quote
I was going to order my chain and sprockets through b and c express but they are closed today, anyone know where i cna order renthal sprockets from?
ta
is that it
Dusty
King of the Rim
PostPosted: 16:44 - 12 Jun 2004    Post subject: Reply with quote
Demon Tweeks?
Arrow 0845 330 4761
<edit>
Sales hotline -
Arrow 01978 664474
</edit>
Gallery
Dr Nick
PostPosted: 17:02 - 12 Jun 2004    Post subject: Reply with quote
Thanks Dusty Thumbs Up Mr. Green
Have decided to downgear my hornet.
Standard gearing is 15/42, gone 1 down at the front and 3 up at the back.
Went with Renthal Sprockets and a DID chain.
is that it
cagiva gezzer
PostPosted: 17:04 - 12 Jun 2004    Post subject: Reply with quote
bike torque racing
01373 464252
www.biketorqueracing.co.uk
Dusty
King of the Rim
PostPosted: 17:11 - 12 Jun 2004    Post subject: Reply with quote
Down gearing? Good move. Thumbs Up
Demon Tweeks aren't the cheapest, but they normally get the correct order to you fairly quickly.
Gallery
Dr Nick
PostPosted: 17:15 - 12 Jun 2004    Post subject: Reply with quote
Thought i had a link extractor, but i can't find it Confused .
Anyone want to lend me one Wink .
is that it
Dusty
King of the Rim
PostPosted: 18:27 - 12 Jun 2004    Post subject: Reply with quote
Can't you just cut the chain?
Gallery
Dr Nick
PostPosted: 23:58 - 12 Jun 2004    Post subject: Reply with quote
What do you mean by 'cut the chain' ?, the guy on the phone from demon tweeks said something about a 122 link chain, which is longer so i can remove links Confused .
is that it
PostPosted: 00:06 - 13 Jun 2004    Post subject: Reply with quote
You can cut the chain to the correct length yourself if you have access to an angle grinder, just make sure you cut it the right length and not to short Smile.
Basically, you fir the new sprockets, set the rear wheel adjustment to the closest it can be, then work out hoe long you need to cut the chain to have it have the correct amount of movement in it that you normally have. If in doubt, seek a second view on it. Smile
Or for a bit of cash in hand a bike shop mechanic will happily do it for you as cash in hand they don't need to put through the tills and pay vat. Mr. Green Thumbs Up
Dr Nick
PostPosted: 00:11 - 13 Jun 2004    Post subject: Reply with quote
No offence, but i don't want to bodge it Razz Mr. Green
is that it
PostPosted: 00:38 - 13 Jun 2004    Post subject: Reply with quote
Its not bodging it, on the ZX6R we did that, then cut the chain very very carefully to the corrct length, checked it was right, then fitted it as well as it can be fitted without a chain tool and then rode it gently to the local shop who did it with thier chain tool Very Happy (they even did it for free Thumbs Up Thumbs Up ). When you are riding it gently I suspect it would be damaged or worked to come off the sprockets if you have a sudden change in acceleration so basically just do everything as gently as you can.
When you are cutting it to the correct length you only need to be cutting the side link bits and no deeper than that as you'll damage the other bits of the chain.
The last post was made 22 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 70.62 Kb
