| Dr Nick |
 Dr Nick World Chat Champion
| Dusty |
 Dusty King of the Rim
 Posted: 16:44 - 12 Jun 2004 Post subject: |
Demon Tweeks?
0845 330 4761
<edit>
Sales hotline -
01978 664474
</edit> ____________________ Gallery |
| Dr Nick |
 Posted: 17:02 - 12 Jun 2004 Post subject: |
Thanks Dusty
Have decided to downgear my hornet.
Standard gearing is 15/42, gone 1 down at the front and 3 up at the back.
Went with Renthal Sprockets and a DID chain. ____________________ is that it |
| cagiva gezzer |
 Posted: 17:04 - 12 Jun 2004 Post subject: |
bike torque racing
01373 464252
www.biketorqueracing.co.uk ____________________ "because one stroke isnt enough and four strokes waste two" |
| Dusty |
| Dr Nick |
 Posted: 17:15 - 12 Jun 2004 Post subject: |
| Dusty |
 Posted: 18:27 - 12 Jun 2004 Post subject: |
Can't you just cut the chain? ____________________ Gallery |
| Dr Nick |
| Ste |
 Ste Not Work Safe
 Posted: 00:06 - 13 Jun 2004 Post subject: |
You can cut the chain to the correct length yourself if you have access to an angle grinder, just make sure you cut it the right length and not to short .
Basically, you fir the new sprockets, set the rear wheel adjustment to the closest it can be, then work out hoe long you need to cut the chain to have it have the correct amount of movement in it that you normally have. If in doubt, seek a second view on it.
Or for a bit of cash in hand a bike shop mechanic will happily do it for you as cash in hand they don't need to put through the tills and pay vat.  |
| Dr Nick |
 Posted: 00:11 - 13 Jun 2004 Post subject: |
No offence, but i don't want to bodge it  ____________________ is that it |
| Ste |
 Ste Not Work Safe
 Posted: 00:38 - 13 Jun 2004 Post subject: |
Its not bodging it, on the ZX6R we did that, then cut the chain very very carefully to the corrct length, checked it was right, then fitted it as well as it can be fitted without a chain tool and then rode it gently to the local shop who did it with thier chain tool (they even did it for free ). When you are riding it gently I suspect it would be damaged or worked to come off the sprockets if you have a sudden change in acceleration so basically just do everything as gently as you can.
When you are cutting it to the correct length you only need to be cutting the side link bits and no deeper than that as you'll damage the other bits of the chain. |
The last post was made 22 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
