| dextersaurus |
 dextersaurus World Chat Champion
 Posted: 21:23 - 24 Aug 2009 Post subject: CG125 seized. |
https://www.youtube.com/watch?v=uIiwJLMrCK4
Please tell me it's saveable.
It's sitting in my back garden now with a litre of oil down the plug hole.
Will try and turn it over tomorrow when it's light and i get more oil to fill up the sump, but please tell me it's not a rebuild
Dunc |
 ..... Quote Me Happy
| dextersaurus |
 Posted: 21:29 - 24 Aug 2009 Post subject: |
Yeah.
Ran out of oil, did what it did in the video and wouldn't turn over.
Emptied the oil down and it freed off a bit with the kickstart, so put more down it and left it overnight.
I think i'll be able to get one from a breakers cheap, we'll see what happens
Dunc |
 Posted: 21:31 - 24 Aug 2009 Post subject: |
I'm afraid that sounds very terminal. ____________________ a.k.a 'Geri'
| dextersaurus |
| Nipedley |
 Nipedley Scooby Slapper
 Posted: 23:17 - 24 Aug 2009 Post subject: |
You're having some bad luck with that CG, fella Hope it turns out alright, didnt sound good though.. Looks like even if it does you got that leak to fix anyhow
Maybe it's time to get that electric start engine, at least then you'd have an upside! |
| dextersaurus |
 Posted: 23:36 - 24 Aug 2009 Post subject: |
See, the newer engines aint as fast, the older ones are much faster.
But they are all kickstart.
Hmm....
Depends on how much they cost
Dunc |
| baldy |
 baldy World Chat Champion
| dextersaurus |
 Posted: 08:19 - 25 Aug 2009 Post subject: |
Im infamous then, i killed a CG.
I don't have the time to do anything just now, im going to have to do it next week sometime.
But i'll post up some pics when i get round to it.
So for now im technically bikeless
Dunc |
| dextersaurus |
| Billing |
 Billing World Chat Champion
 Posted: 10:56 - 25 Aug 2009 Post subject: |
I'd try your current lot, when i seized my ts i let it cool off for a few days and it was fine, so you might very well get lucky. I'd be cautious of a barrel and piston set that cheap, the last cg i rebuilt was £41 for the piston, rings, circlips, gudgeon pin, gaskets and getting the barrel honed. I'd be worried its made of cheese for that price. ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| Nipedley |
 Posted: 11:59 - 25 Aug 2009 Post subject: |
I don't know about faster, two friends I know that have CG's, one has a newer model than me and the other has an old mid 90's and differences in power were minute, the only real difference was between my CG and the newer (2007) one but I think that was as my gearing was changed and that was maybe 1.5mph more at best Just slowly creeped away from him on the dual carriageway, nothing really noticeable |
| temeluchus |
| dextersaurus |
 Posted: 14:14 - 25 Aug 2009 Post subject: Update |
Righto, the piston was freed off last night, and i flushed out the sump and then filled with new oil.
Kicked it over a few times so it could circulate some oil and stuck the spark plug in.
Hooray.
It started, smoke everywhere but that's the oil burning off.
So i got the stethoscope out and looked/listened for any sign of damage i.e. knocking.
Nothing.
I then got the compression tester out... which showed 135.
Seems ok then, maybe i was lucky.
Took it out for a wee run after sorting the idle issue out, was wayy to fast.
So on the run, heard a sound like a compressor letting out air, so stopped and noticed my spark plug was loose.
So tightened that up, and now it's better than it was before, better throttle reaction and sounds nicer too.
So all in all, i think i was a lucky boy. I'll see if anything else happens, just need to sort out those gaskets.
Found what was causing the oil leak
The bloody bolt to drain the oil was loose.
Will upload the video of it belching smoke after i started it.
Dunc |
| Nipedley |
 Posted: 14:17 - 25 Aug 2009 Post subject: |
Very lucky indeed! No oil + seize = performance increase Only with a CG |
| dextersaurus |
 Posted: 14:19 - 25 Aug 2009 Post subject: |
Nahh, it would only happen with me.
I seized a CG that's got to be some kind of record
Dunc |
| Billing |
 Posted: 18:29 - 25 Aug 2009 Post subject: |
| dunc wrote: | Nahh, it would only happen with me.
Dunc |
Nah, the REAL record is totally destroying it till it won't work! Sounds like you were lucky, I'd hazard the piston got really hot, and expanded more than the rings, which is why you still have good compression as a testament to Honda reliability i knocked the sump of my c90 field bike out once, it dropped all the oil, but still wouldnt seize! when it eventually died i threw a set of rings in it and sold it on XD ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| bladerunner |
 Posted: 20:37 - 25 Aug 2009 Post subject: |
I bought (was given) a cg off trchnophobe on here last month. He managed to sieze it good and proper..hole in the piston again lack of oil......not an easy motor to sieze like the cd benleys..they just keep going. new piston and it's back running again now!!! oh and use of a flap wheel to remove the half mill thick aly deposits left in the bore!!!! just as well I'm used to the 2strokes there I think  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| dextersaurus |
| bandit |
 bandit Two Stroke Sniffer
 Posted: 22:58 - 25 Aug 2009 Post subject: |
You where lucky....
The only way to make sure there are no bits of metal in the bottom of your W model is to take clutch case of...
With no sum plug on this model you do not always get all metal particals out ...
When ordering Gaskets make sure you get the metal head gasket not the one older models use...
If your going to put new piston rings you should pay the extra and have rebore... Go for 2mm over size helps with performance..  ____________________ b12 cg125 gt250 kh125 ss50 cg150 CG250cc |
| dextersaurus |
 Posted: 23:22 - 25 Aug 2009 Post subject: |
I love how you knew it was a W model
It's been flushed through with Petrol, might change the clutch soon though, it's tapping a wee bit.
But works fine.
I'll keep running it and see if anything improves as the oil circulates
Dunc |
| dextersaurus |
 Posted: 23:49 - 25 Aug 2009 Post subject: |
Heres the video i forgot to include.
Just after we started it after the oil change.
https://www.youtube.com/watch?v=3bhRJ4u3dCw
Note the smoke coming from the exhaust, the gasket is gone so it's blowing at that point.
Nice sound from it though.
Dunc |
| bandit |
 Posted: 23:52 - 25 Aug 2009 Post subject: |
With the W model on the oil can come out clean with flushing But with no sump plug it still holds 200ml of oil after changing which still can be holding metal particals..
Yours may have no bits in at all but have seen a few when you take of clutch case and tip bike towards you to get last bit of oil out its been full of metal particals
Tapping depends where coming from eg just tappets need ajusting. or if generator side like just above generator it is the cam spindle/ cam gears have got a bit of play due to lack of oil..
Would not worry about it have head plenty that are really badly worn and still running 12 months later..  ____________________ b12 cg125 gt250 kh125 ss50 cg150 CG250cc |
| dextersaurus |
 Posted: 00:00 - 26 Aug 2009 Post subject: |
then it's all good. The oil was cleaned right out, we made sure of it.
Took the cover off and cleaned up in there too to see if there was any obvious damage
But it's all good
Dunc |
The last post was made 17 years, 44 days ago. Instead of replying here, would creating a new thread be more useful? |
