| speedjunkie20... |
 speedjunkie20... Nova Slayer
| Irn-Bru |
 Irn-Bru World Chat Champion
| speedjunkie20... |
| st3v3 |
 st3v3 Super Spammer
| speedjunkie20... |
| binge |
 binge Emo Kiddy
| speedjunkie20... |
| binge |
 binge Emo Kiddy
| tonyts50 |
 tonyts50 Trackday Trickster
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
 MarJay But it's British!
 Posted: 08:40 - 27 Aug 2009 Post subject: |
Just fit a bigger carb, bigger exhaust, adjust the oil pump so it doesn't pump so much oil, and then pour TNT into the fuel tank as this will make your bike fasterer.
Kids don't seem to realise that engine tuning is not about bolting on performance parts, its about carefully measuring and seeing how you can improve an engine from the factory. If bike manufacturers could get more speed just by bolting on a bigger carb etc, then we'd all be riding CB750's with vaaast carburettors wouldn't we?
This, however, is not a case of engine tuning. The bike should have a reasonable performance to begin with so we're into fault finding rather than tuning. In this case, I'd say that changing the carb is about the last thing you want to do. I'd say start by making sure the air filter is clean and free from holes. Then I'd check that the powervalve moves freely and is adjusted correctly. Then I'd check stuff like tyre pressures, chain tension etc. I might even change the spark plug to a new standard spark plug. (NOT iridium). I would also try a plug chop to see if the bike is running rich or lean.
Then, I'd remove the exhaust and have a look up the exhaust port. I'd put my fingers on the piston skirt to see if it moves backward and forward in the bore. If it does, the bike needs a rebore. I'd then move the piston down with the kickstarter (keeping fingers clear of the exhaust port) and shine a light into the bore to try to determine the state of the liner, and to see if there is any other damage.
After that, I'd consider stripping the top end of the engine to see if it needs a rebore or new rings etc. Whilst its stripped, It may as well have a new piston and rings, and a new little end bearing unless the bike has been recently rebuilt.
To be honest, I'd be tempted to give the bike a damn good service, and then possibly try Binge's suggestion of a 1 tooth smaller front sprocket before I started taking stuff off the bike. But then, I am a lazy sod. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
The last post was made 17 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
