little bit more speed?
speedjunkie20...
PostPosted: 23:18 - 26 Aug 2009    Post subject: little bit more speed? Reply with quote
Just got the hole in the exhaust sorted, full comprestion in the exhaust, my top end is 65mph, was just wondering if there any way of getting a little bit more out of it. Its a dt125r 1996 model btw, with a big one exhaust fitted and powervalve fitted.
Irn-Bru
PostPosted: 23:28 - 26 Aug 2009    Post subject: Reply with quote
Removed the restrictor from the exhaust?
speedjunkie20...
PostPosted: 23:36 - 26 Aug 2009    Post subject: Reply with quote
im not sure where the restrictor is on this exhaust? none of the parts have been fitted by myself it was all like this when i bought it
st3v3
PostPosted: 23:43 - 26 Aug 2009    Post subject: Re: little bit more speed? Reply with quote
Are you positive?
speedjunkie20...
PostPosted: 23:50 - 26 Aug 2009    Post subject: Reply with quote
Yeah, got the reciepts from the garage having fitted it, and you can feel it kick in at 8k revs
binge
Emo Kiddy
PostPosted: 00:03 - 27 Aug 2009    Post subject: Reply with quote
Should be doing 75mph easily then. Probably more like 80mph on a DT125 I'd of thought.
Ben
speedjunkie20...
PostPosted: 00:05 - 27 Aug 2009    Post subject: Reply with quote
yeah tis what i thought, it gets to 65 f*****g quick, but then just seems when you go into sixth, the revs drop and it stops accelerating at all?
binge
Emo Kiddy
PostPosted: 00:40 - 27 Aug 2009    Post subject: Reply with quote
Sounds like its dropping out of the powerband when you hit 6th gear.
A quick fix would be fit a smaller front sprocket.
This will make it accelerate faster, But it will also increase the torque, helping it rev out in 6th gear.
I dont really understand 2t tuning myself, But I know that different expansion chambers affect the way the powerband is delivered.
Some spanny chambers give you a really long but subtle power band. And some spanny chambers (Like the one on my pit bike), Give you a really short, But fucking punchy power band.
If you've changed the pipe from standard, It could be that the powerband period has moved up the rev range. In which case a smaller front sprocket will sort it right out.
Ben
tonyts50 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 08:40 - 27 Aug 2009    Post subject: Reply with quote
Just fit a bigger carb, bigger exhaust, adjust the oil pump so it doesn't pump so much oil, and then pour TNT into the fuel tank as this will make your bike fasterer. Rolling Eyes
Kids don't seem to realise that engine tuning is not about bolting on performance parts, its about carefully measuring and seeing how you can improve an engine from the factory. If bike manufacturers could get more speed just by bolting on a bigger carb etc, then we'd all be riding CB750's with vaaast carburettors wouldn't we?
This, however, is not a case of engine tuning. The bike should have a reasonable performance to begin with so we're into fault finding rather than tuning. In this case, I'd say that changing the carb is about the last thing you want to do. I'd say start by making sure the air filter is clean and free from holes. Then I'd check that the powervalve moves freely and is adjusted correctly. Then I'd check stuff like tyre pressures, chain tension etc. I might even change the spark plug to a new standard spark plug. (NOT iridium). I would also try a plug chop to see if the bike is running rich or lean.
Then, I'd remove the exhaust and have a look up the exhaust port. I'd put my fingers on the piston skirt to see if it moves backward and forward in the bore. If it does, the bike needs a rebore. I'd then move the piston down with the kickstarter (keeping fingers clear of the exhaust port) and shine a light into the bore to try to determine the state of the liner, and to see if there is any other damage.
After that, I'd consider stripping the top end of the engine to see if it needs a rebore or new rings etc. Whilst its stripped, It may as well have a new piston and rings, and a new little end bearing unless the bike has been recently rebuilt.
To be honest, I'd be tempted to give the bike a damn good service, and then possibly try Binge's suggestion of a 1 tooth smaller front sprocket before I started taking stuff off the bike. But then, I am a lazy sod.
The last post was made 17 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 70.55 Kb
