Wheel alignment method?
stevie-p
PostPosted: 11:59 - 27 Aug 2009    Post subject: Wheel alignment method? Reply with quote
Does anybody have any good methods for aligning the rear wheel as one of the adjuster bracket things on my swing arm is a bit bent up so not very accurate.
thanks
mr rip
PostPosted: 12:27 - 27 Aug 2009    Post subject: Reply with quote
use a straight edge as a guide like a long plank or a ladder or push it out to the road & use the curb if it's straight
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
PostPosted: 12:29 - 27 Aug 2009    Post subject: Re: Wheel alignment method? Reply with quote
Gave a google for it, or search on here.
There's plenty of methods available to you. I made my own laser alignment thing a while ago (until I needed the laser for something else)... but a piece of string tied to the back of the back tyre is an easy one.
stevie-p
PostPosted: 12:52 - 27 Aug 2009    Post subject: Reply with quote
i did google it and found the string method but surely this only works if you have the front wheel dead straight,
MattEMulsion
PostPosted: 13:45 - 27 Aug 2009    Post subject: Reply with quote
The string method is pretty accurate but is a bit fiddly at first. Once you know what you are doing though it is pretty easy. Nowadays I have two straight edges that I use which is much quicker and simpler to set up, the downside is storing them for that once in a while that you actually require them.
Yamaha YZF-R6
Walloper
PostPosted: 14:53 - 27 Aug 2009    Post subject: Reply with quote
The string method works fine.
No matter how the wheels are.
If you get the same 'out' at the rear of front wheel as you get at the rear of rear wheel (On the other side of the tyre) then you can subtract this from your alignment.
Always seems more complex than it is but trial and error will reap rewards.
It's KERB in the UK. FFS Rolling Eyes Cool
lonner
PostPosted: 16:27 - 27 Aug 2009    Post subject: Reply with quote
hi
measure from the swing arm pivot bolt centre to the rear wheel spindle centre both sides and adjust to achieve the same distance and that will be as near as dammit Thumbs Up
Walloper
PostPosted: 17:39 - 27 Aug 2009    Post subject: Reply with quote
Two different breeds of dog in story I think.
Rear Wheel Centralizing or Wheel Alignment?
Ariel Badger
PostPosted: 17:52 - 27 Aug 2009    Post subject: Reply with quote
I use a lazer pointer mounted on a straight edge that clamps to my rear wheel. you use it just the same as a sting but it is less stringy.
geordiecbrblo...
PostPosted: 19:42 - 27 Aug 2009    Post subject: Reply with quote
https://www.maxton.netspinners.co.uk/files/wheelalignment.htm Thumbs Up
The last post was made 17 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 67.51 Kb
