ZXR4 won't fire up
Fadel
PostPosted: 13:58 - 27 Aug 2009    Post subject: ZXR4 won't fire up Reply with quote
Hi guys,
took the ZXR round the block a few times last week and it was absolutely spot on, parked it up in the garage, went to go fire her up yesterday and she fired up for the whole of 2 seconds before cutting out, after that all she did when I turned her over was backfire and occasionally rumble as if she was about to start.
It would only backfire with the throttle shut and choke off so I assumed it would be flooded as with any choke it just did nothing. Ive had the plug out all night + day, cleaned them up, checked for spark, heated them up and put them back in and nothing. Put some fresh fuel in yesterday, the fuel is getting through (plugs are wet when I took them out) it's getting spark but all it's doing is just turning over and over, it's not backfiring now though but still won't start
Any ideas? Just abit baffled and probably something simple but was fine last week lol
bandit
PostPosted: 14:12 - 27 Aug 2009    Post subject: Reply with quote
Have had this problem before, Its the battery good power to turn over the engine but just not anought for plugs as well; The modern resitor plugs do not like getting wet with feul even with cleaning heating does not work allways.. They can be sparking outside the cylinder but brake down under compression Confused
IF you charge you battery and the try with some new plugs it should run fine.. Very Happy Very Happy
Best of luck
b12 cg125 gt250 kh125 ss50 cg150 CG250cc
Fadel
PostPosted: 14:27 - 27 Aug 2009    Post subject: Reply with quote
Cheers the battery is fully charged up, but suppose it could be that still.
Did yours just need new plugs? the ones in it are pretty much brand new that's the annoying part lol
bandit
PostPosted: 14:40 - 27 Aug 2009    Post subject: Reply with quote
Yep just the plugs and mine where not that old like 200miles worth.. Sad
Now always take it for a min of 15-20 miles run to heat the engine up propely which cleans the plugs of any sooty deposits left buy running on choke... Then put her away for week or 2 or more:D Very Happy
Every time i come to it now starts bag on every time i always charge my battery regular when not using...
Fadel
PostPosted: 15:06 - 27 Aug 2009    Post subject: Reply with quote
Hmm might have to go buy some then try that, cheers for the help, if it doesn't work i'm sure i'll be back lol
Fadel
PostPosted: 16:43 - 27 Aug 2009    Post subject: Reply with quote
Still no joy, has started to rumble + backfire now, really annoying.
Any other ideas?
Ariel Badger
PostPosted: 18:01 - 27 Aug 2009    Post subject: Reply with quote
Did this problem start before or after you put the new fuel in?
It is not unknown to put diesel in a bike.
bandit
If feul was good and can was empty and clean.....
Just wondering did you wash it before you put away with hose etc so some damp has got into electrics some where...
It looks like your going to have to check all connections in wiring on the ingnition side...
I would start simple and check the kill switch is not shorting if you carnt get to the wiring for switch try a good squirt WD40 in switch on and off about 10 time and try bike..
If still not running check other connections back of coils, cdi, ignition switch etc...
It has to be something simple a bad connection as was perfect last time you rode it.....
Fadel
PostPosted: 18:08 - 27 Aug 2009    Post subject: Reply with quote
Did it before I put the fuel in and i'm 100% sure it wasn't diesel.
It's just starting to annoy me, have checked all the electrics, sprayed them with WD etc, checked fuses.
Ariel Badger
PostPosted: 18:13 - 27 Aug 2009    Post subject: Reply with quote
get a tin of this
clicky
bandit
PostPosted: 18:38 - 27 Aug 2009    Post subject: Reply with quote
check the clutch switch under leaver see if thats gone faulty,,
and side stand switch( side stand switch usally only case problem when running)
If not,, may be worth having a bear count to 100 and ask a mate whos good with meter to check electrics....
Best of luck
Ariel Badger
PostPosted: 21:07 - 27 Aug 2009    Post subject: Reply with quote
Bears can not count, even if they could what good would it do?
Ariel Badger
PostPosted: 21:53 - 27 Aug 2009    Post subject: Reply with quote
I just found a link to a short fictional story about a bear that can count by Haruki Murakami.
clicky
Fadel
PostPosted: 22:04 - 27 Aug 2009    Post subject: Reply with quote
Got it running finally!
Not even sure how tbh lol just kept turning it over it backfired a few times then pop as i twisted throttle n finally caught n ran, albeit badly, quick short burst all cleared through n all is well :o Very Happy
Ariel Badger
PostPosted: 22:20 - 27 Aug 2009    Post subject: Reply with quote
All because I found a story about a counting bear! Well done.
Fadel
PostPosted: 22:22 - 27 Aug 2009    Post subject: Reply with quote
Indeed it was sir Thumbs Up
bandit
PostPosted: 23:55 - 27 Aug 2009    Post subject: Reply with quote
It seems where down to the gremlins Sad
But at least we can still have a bear or 2 Very Happy Very Happy
The last post was made 17 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 95.3 Kb
