| ScreamWorker |
 ScreamWorker Nitrous Nuisance
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 18:26 - 27 Aug 2009 Post subject: |
Old* engine oil applied with a toothbrush, leave to 'soak' and then wipe off excess with old rag.
*Of course new oil could be used too. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| B10Hazard |
 B10Hazard World Chat Champion
| ScreamWorker |
 Posted: 19:34 - 27 Aug 2009 Post subject: |
ok thanks guys, im guessing im proberbly putting way to much on and not removing the exxcess  |
| That_Hornet |
 That_Hornet World Chat Champion
 Posted: 19:43 - 27 Aug 2009 Post subject: |
shouldn't take 2 hours to get it off.
Use WD40 and i should come off in minutes.  |
| ScreamWorker |
 Posted: 19:45 - 27 Aug 2009 Post subject: |
ahh thanks ill try that next time !  |
| Noxious89123 |
 Posted: 20:59 - 27 Aug 2009 Post subject: |
ScottOilers are very good, the only time you'll get problems with it flinging oil off is if you set the flow too high.
When ever i clean the chain, i re-lube it by pouring som ScottOil on a rag, and running the chain through it, just to leave a film of oil on he chain. Stops it rusting, and keeps fling-off non-existant. Then th oiler just keeps it nice and fresh looking  ____________________
| knocker |
 knocker Nova Slayer
| serlant |
 serlant Brolly Dolly
| chris-red |
| temeluchus |
| Mark65 |
 Mark65 World Chat Champion
 Posted: 08:04 - 28 Aug 2009 Post subject: |
I just use heavy gear oil about 3 times a week or after riding in rain, once you do it a few times its quick, it takes me about 10 mins to lube and wipe off excess and i very rarely have to clean the chain plus it doesnt get the build up of shit in between the links like grease does. Shiny clean, the gear oils was about £3.50 and ive been using the small bottle about 2 months so far, the trick is not to pour on chain while spinning back wheel but todribble on fingers and rub onto chain then turn wheel and wipe of excess, my bike has 4300 miles now and ive adjusted the chain once, it is just a tad past the second mark on the rear adjuster so its moved about 2mm on that since i got it.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| sickpup |
 sickpup Old Timer
| Whosthedaddy |
| arry |
 arry Super Spammer
| Whosthedaddy |
| tonyts50 |
 tonyts50 Trackday Trickster
| FerretFing |
 FerretFing World Chat Champion
| Darth |
 Darth World Chat Champion
| veze |
 veze Trackday Trickster
| Noxious89123 |
 Posted: 22:05 - 28 Aug 2009 Post subject: |
Just to add to this;
The SDoc100 chain cleaner is fooking immense! Spray on, leave for 10 mins, then hose off (I do it just before i wash the bike). All the muck and shit just rops straight off, it's awsome. ____________________
| BlackStallion |
 BlackStallion Crazy Courier
 Posted: 22:57 - 28 Aug 2009 Post subject: |
Clean and apply lube on a warm chain, so after you've come home. If not ride about for about 15 minutes.
Use an old rag and some Kerosene, then a toothbrush to get in the gaps.
Then apply Wurth High Performance Dry Chain Lube, works a treat, about 2 coats, and your chain is looking good. Make sure you leave it for about 20 minutes and then go on another 15 minute ride to get the chain warm again.
With Dry Lube, you won't get the black goo which builds up on your wheel rim. So don't worry about that
After using it, you literally won't use anything else. |
The last post was made 17 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
