 BenR World Chat Champion
 Posted: 18:30 - 27 Aug 2009 Post subject: Fork seals? |
Hi after buying a set of fork seals for my rg 125 wolf from ebay & finding they didn't fit I went & paid £53 for genuine suzuki items only to now find they don't fit either! Are fork seals generally too big, do you have to heat them up in order to fit them or something? Any help much appreciated. BTW they're normal RWU forks not USDs (it's been a long time since I changed a set ) ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
 Posted: 19:05 - 27 Aug 2009 Post subject: |
You would normally have to drive them into position in the fork legs with a fair degree of force but they should slide over the stanchions fairly easily.
Put PVC tape round the top of the stanchion so you don't damage them as they slide on. A popular way to drive them into place (in the absence of the proper tool) is to use a bit of plastic water pipe that is wider than the stanchion but narrower than the seal. Slide the seal down over the stanchion so it rests against its seat, put the pipe over the top and tap it down with a mallet/block of wood. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 serlant Brolly Dolly
