Thermals under leathers?
SamJL
PostPosted: 02:52 - 29 Aug 2009    Post subject: Thermals under leathers? Reply with quote
As its coming in to winter, and I hate riding without my leathers on, I was wondering what thermals I can buy to wear under them?
Ive found this site:
https://www.motorbike-crazy.com/Shop/Clothes-Thermal.html
Would those thermolite jacket and pants be ok? Or should I go for the anti freeze thermal's?
I dont quite understand the difference! Im sure they would both go under my leathers!
Or does anyone else have any good suggestions to some decent thermals to wear under my leathers?
Thanks, Sam
mooserx
PostPosted: 06:32 - 29 Aug 2009    Post subject: Reply with quote
I got a set of thermals, long johns and a long sleeved top, for £7 from aldi, bargain.
Isn't it already warm in leathers?
Not when it starts getting chilly.
TL1000r-handful.
Tonka
PostPosted: 09:05 - 29 Aug 2009    Post subject: Reply with quote
Hmm, what a thread to be starting in August! Either you're being super well prepared or the weather is already all wintery...... Thinking
Just an observation as I do get really cold very quickly on the bike so have to wear thermal stuff for about 9 months of the year. I already had thermal gear for general stuff like hiking etc. and it was ok on the bike. Decided to be a tart and invest in proper bike thermals and found quite a difference as there is extra wind protection on the bits you need protecting.
I'd say if you're going to be using them a lot and can afford them then buying the proper bike stuff is worthwhile. If it's for occasional use then the normal thermals will be adequate.
PostPosted: 10:12 - 29 Aug 2009    Post subject: Reply with quote
Skiing and hillwalking thermals are not quite as extortionately overpriced as motorbike ones. Look for "technical layer" thermals. They are very thin and wick sweat away, also take a while to start to stink.
bunglehaze
PostPosted: 14:28 - 29 Aug 2009    Post subject: Reply with quote
Yeah bike undersuits are crazy priced for what they are and there are non-biking versions you can find cheaply enough. I got an EDZ undersuit and think its ok but neck to crotch height is a bit tight sometimes - I am only 5'11" too.
It is a godsend in summer though being a 1 piece it makes it easy to get my suit off on hot days, a 2 piece version would be ok for winter when the 1 piece leathers wont get worn.
cheers
leigh Very Happy
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
Kwaks
I'm not a fast rider
PostPosted: 14:40 - 29 Aug 2009    Post subject: Reply with quote
If you can afford to I would suggest aquiring textiles.
Nowt worse than pulling sodden leathers back on
www.cliqueycuntsmcc.co.uk
Bikeless
PostPosted: 15:12 - 29 Aug 2009    Post subject: Reply with quote
you can buy the fancy bike stuff but i always buy cheap pringle ones from TK Max.
The Tot
PostPosted: 15:20 - 29 Aug 2009    Post subject: Reply with quote
Primark 4-5 quid for long johns and thermal long sleeves... DONE
Never argue with autism
SamJL
PostPosted: 18:22 - 29 Aug 2009    Post subject: Reply with quote
Thanks guys!
Ill go and invest in some cheap thermals then.
My leathers are summer leathers, so there very vented with tiny holes all over them to get you cool. A bit annoying when it starts to get chilli but good in the summer!
Ive got textiles but I hate riding in them, I just don't feel protected enough, so Ill nip in to my local TK Max and Primark and get a thermal 1 peice.
Thanks Very Happy
TheFoxyDuke
PostPosted: 18:56 - 30 Aug 2009    Post subject: Reply with quote
I got a set of base layers from either Aldi or Lidl (I forget) for not much more than a tenner for both and wear them all the time under my 1 piece. For the price I couldn't fault them at all and also wear them if I'm off cycling or hiking with the mutt.
If it's really nippy a cheap thin t -shirt and the wifes leggings go on as well Embarassed
To be honest I don't think it's important to spend a massive amount when it's really the layering effect which makes a difference.
Works well for me anyway Wink
FoxyD
Currently : Ducati Monster S4R 2005, 996cc, Blue with Corse stripe, Open Carbon Clutch Cover (TokaTokaTokaToka), Marchesini 5 Spoke Wheels, 117BHP.
Wanted : Ducati 749S 2005 onwards.
Rate my Posts, You Sons of Bitches!
SamJL
PostPosted: 00:23 - 31 Aug 2009    Post subject: Reply with quote
Thanks!
Think im going to get an Arlen Ness rain suit for some rainy track days aswell, they have a cut out for knee sliders Very Happy
Ill get some thermals, was just seeing if they actually worked, and they obviously do!
Thanks, Sam
Stelmer
PostPosted: 01:21 - 31 Aug 2009    Post subject: Reply with quote
1pc Fleece undersuits used with Drysuits are useful.
Don't wear it anymore since getting some coldkillers ½ price at last years' NEC show. If you can afford it, I recommend the Windstopper jacket.
Noxious89123
PostPosted: 20:44 - 31 Aug 2009    Post subject: Reply with quote
I used to wear an extra pair of boxers, extra pair of socks, 2 t-shirts over an Edz thermal layer, and a buff. Then my leathers. Then my 1-peice waterproofs over the top to keep the wind out.
Kept me mostly warm, the worse thing though is trying to keep feet and hands warm. After about an hour they start to go numb, at the 2 hour mark they hurt like Fck.
The pain when you go from sub-zero temperatures into a warm room is HORRENDOUS. Like when you put cold hands under the hot tap.
I used to get home and take my gloves off, and stand around outside for a few minutes whilst they unfroze, before going indoors.
The hole for the knee sliders will let water in, which will run down your leg and into your boots. Not fun. Oh how I love full GoreTex lined boots Mr. Green
I used to ride all year round in all conditions, and it's not fun, can be a bit of an advnture though. Done it for 2 winters, and that's enough for me... Now I have a Ford Ka for those days.
What bike are you riding? Sportsbikes with semi-slick tyres don't like snow Thumbs Down Laughing
BanditJeff
PostPosted: 20:59 - 31 Aug 2009    Post subject: Reply with quote
FoxyD
I've got them. It was Aldi that were doing the ones i got. They usually repeat their bike gear, as do Lydl.
Really good thermals for the price and ultra thin & stretchy..... although i dont wear them until around nov / dec onwards.
EUMP
PostPosted: 21:22 - 31 Aug 2009    Post subject: Reply with quote
Textile time of the year Smile always found them more warm with the inner removable lining! if your still cold jumper or a hoody works well Laughing
C.B.T - Expired
MOD1 04/08/10
MOD2 10/08/10
SamJL
PostPosted: 00:02 - 01 Sep 2009    Post subject: Reply with quote
Im riding a CBR1000RR, with Metzler Racetec's
So a sports bike with semi slicks!
Ill just go and pick some cheap thermals up, and Im going to try on one of those Arlen Ness rain suits for some track days on full wets Very Happy
Ive got a couple of cars and van aswell, but I want to ride the bike as much as possible as I've only just bought it!
Mudskipper
PostPosted: 08:20 - 01 Sep 2009    Post subject: Reply with quote
Army surplus thermals FTW. Thumbs Up
leeclissett
PostPosted: 15:46 - 02 Sep 2009    Post subject: Reply with quote
Under Armour technical layers are the dogs bits, I thought it was all voodoo but a fellow referee recommended them for winter and summer and I've never looked back. They are compression type unders so keep your body heat in, keep the cold out and because they are literally skin tight you get nice warm air between them and your leathers. The key isn't getting you warm, its maintaining a comfortable level of body heat and these do it like no other.
I wear the heat gear under armour during the summer too, same principal but it wicks sweat away from your body, when you take your leathers off just rip off your under armour and your body is bone dry and somehow the shirt smells to high heaven from sucking up your sweat and you smell lovely and fresh.
If you're sensible you can find them in JJB sports for £25 a piece.
Stelmer
PostPosted: 00:38 - 03 Sep 2009    Post subject: Reply with quote
I have the coldkillers ones and the Aldi ones.
Both work superbly well but impractical for day to day use as you need to wash them practically after every ride.
kitty kat
PostPosted: 06:10 - 03 Sep 2009    Post subject: Reply with quote
With Mudskipper, army surplus.
I wear a thermal long sleeved vest & a norgi under my leathers, they work well and cheap as well Smile
SamJL
PostPosted: 13:08 - 03 Sep 2009    Post subject: Reply with quote
Im even more confused now!
If money was no object, you just wanted the warmest windproof thermals, what would be the best to buy?
Money is an object but I dont mind spending up to around £100 to keep warm in the winter! My leathers have little breathing holes all over them so it can get a bit chilli!!
Bikeless
PostPosted: 13:53 - 03 Sep 2009    Post subject: Reply with quote
I would buy some cheap thermals and get yourself some wind/waterproof jacket and trousers,either motorcycle based ones or get some from a camping shop.
Noxious89123
PostPosted: 16:33 - 03 Sep 2009    Post subject: Reply with quote
If your wearing vented leathers like i do, then i demand you buy a 1 piece waterproof suit.
Makes more difference in keeping you warm than anything else suggested will.
Layers are good, but if you've got no wind protection, you'll still freeze. A waterproof suit will be 100% windproof.
The last post was made 17 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 129.31 Kb
