Tightening the nut on front sprocket?
PostPosted: 19:30 - 30 Aug 2009    Post subject: Tightening the nut on front sprocket? Reply with quote
I need to tighten it to 98nm (72ft-lb).
So what's the best way of locking it while i do it?
Jam the back brake on but that means a lot of stress on the chain?
The previous owner obviously wasn't sure either as the twat obviously just left it loose Evil or Very Mad
Thanks
Dave
MaybeGuy
PostPosted: 19:34 - 30 Aug 2009    Post subject: Reply with quote
98nm is nothing compared to the strain even a bicycle chain can take.
PostPosted: 19:36 - 30 Aug 2009    Post subject: Reply with quote
Cheers matt Thumbs Up Just wanted to check Smile
Will go do it now.
Karma
PostPosted: 22:04 - 30 Aug 2009    Post subject: Reply with quote
I used to jam an M6 bolt between the chain and sprocket to "lock" it in position.
alun111
PostPosted: 03:23 - 31 Aug 2009    Post subject: Reply with quote
Put it in gear?
PostPosted: 07:27 - 31 Aug 2009    Post subject: Reply with quote
Put a bar/piece of timber through the rear wheel to stop it against the swing-arm.
supZ
PostPosted: 10:46 - 31 Aug 2009    Post subject: Reply with quote
alun111 wrote:
Put it in gear?
will still slip under that load.
i just use the brake method but i've seen the bolt in chain/sprocket method work too
CBR954RR - Daily toy
CBR600RR - Trackbike
Stelmer
PostPosted: 13:18 - 31 Aug 2009    Post subject: Reply with quote
I got someone to sit on the bike, put it in first, pushed up against the wall and hold both brakes on.
That was on the ER. Not done the GSX one yet as there's loads of life left in the chain. Not looking forward to doing it either.
alun111
PostPosted: 13:34 - 31 Aug 2009    Post subject: Reply with quote
supZ wrote:
alun111 wrote:
Put it in gear?
Ah, fair enough.
I just looked in the manual and now remember that my hornet only required 54nm.
cyberglass
PostPosted: 13:42 - 31 Aug 2009    Post subject: Reply with quote
I use the jam the back brake on method.
If you think about it the torque you generate is nothing compared to what you bikes putting out under throttle or the stress the chain is under when you pop a wheelie lifting the bike and yourself up Mr. Green
the sprocket nut should have a little piece on the nut to bash into a reces on the shaft to stop it undoing if it were to losen up.
Dont forget to bash it in. Thumbs Up
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
PostPosted: 13:47 - 31 Aug 2009    Post subject: Reply with quote
Could just put a bit of wood through the rear wheel to stop it turning then tighten up.
As said 98Nm on a chain is nothing compared to the 100 odd bhp that it usually has to cope with.
PostPosted: 14:15 - 31 Aug 2009    Post subject: Reply with quote
Actually it is by my reckoning but still not enough to hurt the chain. Most times it will not hold on the brake though.
A 100hp bike will be making about 65NM of torque, but final drive at say 16/41 ratio has multiplied that so you're only making 25.3nM maximum at the front sprocket as an example. Putting a torque wrench on there and pulling it to 97nM is nearly four times more pull on the chain than the bike would normally make.
PostPosted: 14:21 - 31 Aug 2009    Post subject: Reply with quote
Fair. Thumbs Up
The last post was made 17 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 77.35 Kb
