| Trylski |
 Trylski Scooby Slapper
 Posted: 18:34 - 30 Aug 2009 Post subject: Bike running a tad sluggish |
When opening the throttle all the way at anything under 8k and the engine bogs for a few seconds before picking up. The low end accelleration is more or less the same as when it was 33bhp. The top end is also only about 108mph Indicated.
I have discovered this all since finding my Restrictors had fallen out somehow while I did the valve clearances.
Question is: Could it be I've cocked the valves up?
Carbs need fiddling with?
Bit of paper says its just the blades in the inlet.
Cheers for replies ____________________ Current Bike: Suzuki Bandit N600 '99,
- CBT: Passed 02/2008 - Theory : Passed 24/02/09 Test: Passed 09/03/09 - 2011 33bhp over
| Timmeh |
 Timmeh World Chat Champion
 Posted: 20:13 - 30 Aug 2009 Post subject: |
If you'd made a mess of your valves chances are you'd blown it up by now. Definately sounds like a fuelling problem, maybe the pilot jets were changed up as it sounds like its running rich.
A plug chop is your friend.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Trylski |
| MaybeGuy |
 MaybeGuy Super Spammer
| Trylski |
| MaybeGuy |
 Posted: 20:54 - 31 Aug 2009 Post subject: |
what bike is it? i assumed it was shims, not rockers. ignore the timing thing if you havnt changed it. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| yuri2085 |
 yuri2085 World Chat Champion
 Posted: 23:04 - 31 Aug 2009 Post subject: |
Throwing in a air filter/ jetting here with no real experience. You wouldn't notice the dodgy air filter as much with the restriction in so perhaps it just needs a clean/new one.
Basically look at the air filter, is it really grimey?-worth looking as its so easy . |
| Trylski |
 Posted: 07:25 - 01 Sep 2009 Post subject: |
@Mattsprattuk:
Its a 99 bandit 600 mk1. Haynes manual calls the top of the block the "valve rocker cover". Might be a clue
@yuri: Air filter has a pretty dirty circle that lines up with the spout of the air filter. Will clean it at the weekend. ____________________ Current Bike: Suzuki Bandit N600 '99,
- CBT: Passed 02/2008 - Theory : Passed 24/02/09 Test: Passed 09/03/09 - 2011 33bhp over |
The last post was made 17 years, 23 days ago. Instead of replying here, would creating a new thread be more useful? |
