Bike running a tad sluggish
Trylski
PostPosted: 18:34 - 30 Aug 2009    Post subject: Bike running a tad sluggish Reply with quote
When opening the throttle all the way at anything under 8k and the engine bogs for a few seconds before picking up. The low end accelleration is more or less the same as when it was 33bhp. The top end is also only about 108mph Indicated.
I have discovered this all since finding my Restrictors had fallen out somehow while I did the valve clearances. Rolling Eyes
Question is: Could it be I've cocked the valves up?
Carbs need fiddling with?
Bit of paper says its just the blades in the inlet.
Cheers for replies
Current Bike: Suzuki Bandit N600 '99,
- CBT: Passed 02/2008 - Theory : Passed 24/02/09 Test: Passed 09/03/09 - 2011 33bhp over
Timmeh
PostPosted: 20:13 - 30 Aug 2009    Post subject: Reply with quote
If you'd made a mess of your valves chances are you'd blown it up by now. Definately sounds like a fuelling problem, maybe the pilot jets were changed up as it sounds like its running rich.
A plug chop is your friend.
Trylski
PostPosted: 20:26 - 30 Aug 2009    Post subject: Reply with quote
Will do a plug chop tomorow evening. Its too late to do one now.
MaybeGuy
PostPosted: 10:55 - 31 Aug 2009    Post subject: Reply with quote
ignore that.
if you'd made a mess of your valve clearances, and got them wrong, then you could very likely have an engine that runs like you're describing.
are you sure you timed it properly?
Trylski
PostPosted: 19:02 - 31 Aug 2009    Post subject: Reply with quote
I couldn't say about the timing.
It was my first go at anything this technical so I've no idea what I may or may not have done with the timing.
I just used a feeler gauge in the valve and tightened as nessicary.
MaybeGuy
PostPosted: 20:54 - 31 Aug 2009    Post subject: Reply with quote
what bike is it? i assumed it was shims, not rockers. ignore the timing thing if you havnt changed it.
yuri2085
PostPosted: 23:04 - 31 Aug 2009    Post subject: Reply with quote
Throwing in a air filter/ jetting here with no real experience. You wouldn't notice the dodgy air filter as much with the restriction in so perhaps it just needs a clean/new one.
Basically look at the air filter, is it really grimey?-worth looking as its so easy Smile.
Trylski
PostPosted: 07:25 - 01 Sep 2009    Post subject: Reply with quote
@Mattsprattuk:
Its a 99 bandit 600 mk1. Haynes manual calls the top of the block the "valve rocker cover". Might be a clue Razz
@yuri: Air filter has a pretty dirty circle that lines up with the spout of the air filter. Will clean it at the weekend.
The last post was made 17 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 58.2 Kb
