| Frost |
 Frost World Chat Champion
| Hex |
 Hex Party Boy
 Posted: 21:32 - 13 Jun 2004 Post subject: |
Tooth brush and some paraffin. give the tight link and those either side a good clean, and work till its loose.
Then wash/rinse with water and dry and re-lube the chain.
The paraffin wont damage the o rings like wd40 will etc and when washed it will more or less wash off leaving a nice clean free link for the lube!
remember lube is best put on after a ride, as the chain is warm and the gaps more open for the lube to get into. But do put some lube on after cleaning the chain. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| robbiehall |
 robbiehall Renault 5 Driver
| Frost |
| Hex |
 Hex Party Boy
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 16:07 - 14 Jun 2004 Post subject: |
When i was in france i managed to go past the tightspot stage and kink my chain, due to my scott oiler having an airlock and me not noticing, all i did was...like gav said, used a wire brush with some silkolene chain spray , cleaned the link as well as i could and sprayed the thing with oil...i then also went about 30 miles with my oiler on purge, that sorted me out  ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| Hex |
 Hex Party Boy
 Posted: 22:26 - 14 Jun 2004 Post subject: |
My understanding is the pin has the o ring round yes? As the o ring perishes it allows the pin to move more.
So no real stretch occurs as such more wear allowing more movement. Guess it depends on your meaning of "stretch.  ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
| robbiehall |
 Posted: 12:19 - 16 Jun 2004 Post subject: |
OK, I see, then that is normal, every chain I have ever had has a low and a high part of it's run. You should adjust where the tightest part gives the correct slack (whatever it recommends in the manual). Not sure what causes it, but have always been told to use that method.
Weird that, look at 'tightest' and it just looks WRONG, like when you look at the same word over and over again, they start to look like you are not spelling them correctly !!IMHO that is....
Yes I agree it seems funny that a chain might stretch (seeing as it is hard metal), but it is the overall wear in the links that, added up, makes the overall length, ermm, longer.
Cheers
Rob ____________________ The older I get, the faster I was. |
| Frost |
 Posted: 19:42 - 16 Jun 2004 Post subject: |
I would not be certain this is the problem, but you could get a similar tight spot if the rear sprocket was not mounted concentrically with the rear wheel spindle. However you would have a tight spot / loose spot with each turn of the back wheel rather than of the whole chain.
Suppose a similar problem with the front sprocket (maybe the output shaft from the gearbox being bent) could also do the same, and maybe combine with rear sprocket problem to make the situation worse.
The last post was made 22 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
