Chain tight spot
Frost
PostPosted: 21:10 - 13 Jun 2004    Post subject: Chain tight spot Reply with quote
Does anyone have any expirence with removing a tight spot in a chain?
I just replaced the rear sprocket on my bike and it has caused one hell of a tight spot int he chain, it makes the bike near unrideable so any advice you might have would be greatly apreciated!
Hex
Party Boy
PostPosted: 21:32 - 13 Jun 2004    Post subject: Reply with quote
Tooth brush and some paraffin. give the tight link and those either side a good clean, and work till its loose.
Then wash/rinse with water and dry and re-lube the chain.
The paraffin wont damage the o rings like wd40 will etc and when washed it will more or less wash off leaving a nice clean free link for the lube!
remember lube is best put on after a ride, as the chain is warm and the gaps more open for the lube to get into. But do put some lube on after cleaning the chain.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
robbiehall
PostPosted: 13:24 - 14 Jun 2004    Post subject: Reply with quote
Why did you have to replace the sprocket? was it badly hooked (worn)? If so then you will find the chain has stretched, helping to cause the hooked teeth as it rides up over the sprocket teeth. They ought to be replaced as a set.
The tight spot may come out with a clean and lube, as it may be caused by dirt/rust/dry running, but personally I would take it as a sign to replace the chain.
Also can you pull the chain away fom the sprocket?, a good wear indicator too.
The next set I buy will be kept as clean as possible, and I will try Castrol Chain Wax and not oil or greasy chain spray. and I will check the chain for wear as often as I can.
IMHO
Rob
The older I get, the faster I was.
Frost
PostPosted: 13:33 - 14 Jun 2004    Post subject: Reply with quote
Old sprocket was not worn, chain is new, sprocket was replaced due to me altering the gearing.
By tight spot i mean the chain has just the right amount of slack in it, yi turn the back wheel a bit, the chain stays just slack enough, then it gets really tight. I keep turning the back wheel and it slackens off again.
When riding this causes the bike to pulse forwards rather than accelorate smoothly.
Hex
Party Boy
PostPosted: 14:13 - 14 Jun 2004    Post subject: Reply with quote
Common misconception, the chain actually doesn't stretch, what happens is the o rings dry out and as such allow more movement in the chain thus causing more slack.
This is why a well lube chain doesn't need as much adjustment as a one that isn't. Simply because the o rings are kepts lubed and they don't dry out.
craigT19
Jolly Green Giant
PostPosted: 16:07 - 14 Jun 2004    Post subject: Reply with quote
When i was in france i managed to go past the tightspot stage and kink my chain, due to my scott oiler having an airlock and me not noticing, all i did was...like gav said, used a wire brush with some silkolene chain spray , cleaned the link as well as i could and sprayed the thing with oil...i then also went about 30 miles with my oiler on purge, that sorted me out Razz
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
PostPosted: 21:47 - 14 Jun 2004    Post subject: Reply with quote
Chains do stretch. The O rings should have no real load on them. The major part of what happens seems to be the pins in the chain wear. Even if each one wears by 0.1mm then that is a 100 link chain about 1cm longer.
Hex
Party Boy
PostPosted: 22:26 - 14 Jun 2004    Post subject: Reply with quote
My understanding is the pin has the o ring round yes? As the o ring perishes it allows the pin to move more.
So no real stretch occurs as such more wear allowing more movement. Guess it depends on your meaning of "stretch. Smile
PostPosted: 23:59 - 14 Jun 2004    Post subject: Reply with quote
The O ring goes around the pin, but between the side plates. There should be load on it. As the O ring wears the lubricant inside the chain leaks out so the it can wear rapidly and get longer.
robbiehall
PostPosted: 12:19 - 16 Jun 2004    Post subject: Reply with quote
OK, I see, then that is normal, every chain I have ever had has a low and a high part of it's run. You should adjust where the tightest part gives the correct slack (whatever it recommends in the manual). Not sure what causes it, but have always been told to use that method.
Weird that, look at 'tightest' and it just looks WRONG, like when you look at the same word over and over again, they start to look like you are not spelling them correctly !!IMHO that is....
Yes I agree it seems funny that a chain might stretch (seeing as it is hard metal), but it is the overall wear in the links that, added up, makes the overall length, ermm, longer.
Rob
Frost
PostPosted: 15:39 - 16 Jun 2004    Post subject: Reply with quote
I only asked, as my dad had a JH-90 years ago (basically a geared honda 90 commuter). the chain on that had one hell of a tight spot on it. He replaced both sprockets and the chain as a matching brand new set. yet still he had exactly the same tight spot that just would not go away no matter what he tried.
PostPosted: 19:42 - 16 Jun 2004    Post subject: Reply with quote
I would not be certain this is the problem, but you could get a similar tight spot if the rear sprocket was not mounted concentrically with the rear wheel spindle. However you would have a tight spot / loose spot with each turn of the back wheel rather than of the whole chain.
Suppose a similar problem with the front sprocket (maybe the output shaft from the gearbox being bent) could also do the same, and maybe combine with rear sprocket problem to make the situation worse.
The last post was made 22 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 77.86 Kb
