Peugeot Speedfight leaking fuel.
JamesSpeedfig...
PostPosted: 20:32 - 31 Aug 2009    Post subject: Peugeot Speedfight leaking fuel. Reply with quote
Hi, I've got a Speedfight from a friend, and it has been standing for a few years, everything was removed for it to be resprayed. This included the fuel tap. We tried starting the bike, and the starter motor was working fine and as the bike has no exhaust fitted at the minute, we could hear the pistons moving up and down. The problem is, we have connected the two pipes, (Not sure what one is which!!) and when we pour fuel into the tank, it leaks all over the floor, does anyone know what the problem could be?
https://i32.tinypic.com/2gv9bf7.jpg
Problems with a Speedfight, help.
finpos
PostPosted: 20:45 - 31 Aug 2009    Post subject: Reply with quote
It's either working exactly as intended or it's completely broken.
Where, exactly, is it leaking from?
Does it leak all the time, or only when you are turning the engine over?
By the way, you'll probably have to put the exhaust on to make it start.
f.
Timmeh
PostPosted: 20:47 - 31 Aug 2009    Post subject: Reply with quote
Put one of the pipes on the bit at the bottom.
Turn the engine over.
If fuel comes out, it's the right one, if it isn't, it's the other hose.
HTH
Timmeh
PostPosted: 20:49 - 31 Aug 2009    Post subject: Reply with quote
The fuel leak will caused by a perished or missing o-ring seal or gasket that sits between the top of the fuel tap and the tank.
replace.
EUMP
PostPosted: 21:29 - 31 Aug 2009    Post subject: Reply with quote
Timmehs' hit the spot on the second of his post Smile let us know if it leaks anymore'
C.B.T - Expired
MOD1 04/08/10
MOD2 10/08/10
mr rip
PostPosted: 21:41 - 31 Aug 2009    Post subject: Reply with quote
the upper of the two outlets on your tap is the fuel feed to your carb,
the lower one is the vaccuum pipe to open the tap
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
JamesSpeedfig...
PostPosted: 22:16 - 31 Aug 2009    Post subject: Reply with quote
Cheers for your speedy replies guys Thumbs Up
But it's leaking fuel when its POURED into the tank, not when it is starting so im guessing its something to do with the o-ring seal.
finpos
PostPosted: 23:06 - 31 Aug 2009    Post subject: Reply with quote
...depends where it's leaking from!
f.
JamesSpeedfig...
PostPosted: 23:19 - 31 Aug 2009    Post subject: Reply with quote
f.
Well it's leaking all down the tap so my guess is that it is the o-ring, i don't know where to obtain one from.
finpos
PostPosted: 23:33 - 31 Aug 2009    Post subject: Reply with quote
Looks more like a missing washer, my guess would be that when the tap was removed it got stuck to the tank and subsequently was lost. Any petrol-proof soft washer that fits will do - go to halfords and buy a pack if you are desperate.
One thing to do first, though, is make sure you have assembled it correctly. The white bit in the picture there is a fuel filter, and if you look at the bottom of it, the "washer" may actually be a part of that - it will be shaped like a very tall top-hat. It should be obvious, the rim of the top-hat will be trapped between the fuel tap and the tank itself, making a seal.
f.
JamesSpeedfig...
PostPosted: 10:29 - 01 Sep 2009    Post subject: Reply with quote
Ok we have managed to fix the fuel tap, now a larger problem has arrised. When using the electric start, the engine turns but does not fire, any ideas?
The last post was made 17 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 65.66 Kb
