| BlackStallion |
 BlackStallion Crazy Courier
 Posted: 15:15 - 31 Aug 2009 Post subject: Slight problem, bike seems to chug a lot, any advice? |
I changed my spark plug a couple of days ago, i fitted an Iridium instead of Standard.
Since that change i realised an increase in power when in 5th.
But now my bike is chugging a lot when changing gear
It shudders a bit and it never used to do that, always had clean gear shifts, nice smooth acceleration and no stuttering whatsoever...
It must be something to do with the spark plug, but i'm not sure?
Another thing, i had to take my cylinder head cover off to get into the hole to unscrew the spark plug, as i didn't have a tool small enough. Which was a pain in the arse.
You don't think i disturbed anything?
This is the reason i fitted an Iridium plug, as it's such a chore to change it.
Please help guys
Thanks in advance  |
| BlackStallion |
 Posted: 20:03 - 31 Aug 2009 Post subject: |
Anyone?
I'm hoping to sort this out tomorrow...
By the amount of replies, i'm taking it that this is a pretty stupid post, i bet there is such a simple explanation...
I'm just not 100% with the mechanics of bikes  |
| T0MMY |
 T0MMY World Chat Champion
 Posted: 20:08 - 31 Aug 2009 Post subject: |
Don't think it's a stupid post, just nobody knows the answer
Is it steam powered at all? Have you checked the coal? ____________________ ZX6R + CBR600RR |
| Paulington |
 Paulington World Chat Champion
| BlackStallion |
 Posted: 20:17 - 31 Aug 2009 Post subject: |
yeah hopefully, don't want to look like a complete idiot.
No it isn't steam powered, just oil cooled.
You don't think it's the engine oil?
Air filter?
Anything?
Thanks for the reply T0MMY  |
| ms51ves3 |
 ms51ves3 Super Spammer
| T0MMY |
| Ariel Badger |
 Ariel Badger Super Spammer
| Paulington |
| BlackStallion |
| Paulington |
 Posted: 20:25 - 31 Aug 2009 Post subject: |
| milkster125 wrote: | What would it do if i disturbed the head gasket?
It's quite weird, as i was out on my bike earlier, and it didn't chug once, then on the way home it started again. I'm shifting properly, i'm blipping the throttle when changing gear, i'm riding it correctly, just a problem mechanically.
I hope it isn't the spark plug, hate to change it again. I don't think it is as it's been starting up brilliantly, top speed hasn't lowered or increased, just the chugging every now and then... |
I wouldn't worry about the head gasket, unless you took off the actual cylinder head (could see inside the cylinders) you won't have disturbed it. ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| Moo. |
 Moo. World Chat Champion
| That_Hornet |
 That_Hornet World Chat Champion
| T0MMY |
| BlackStallion |
 Posted: 20:31 - 31 Aug 2009 Post subject: |
Yeah, i never saw the cylinder head, it was just the cover with the oil in and the centre hole where the plug was.
To T0MMY
I have to admit, although the spark plug was the same one, just in Iridium, it didn't seem to screw down as far as my standard one. I screwed it as far as it would go, not hand tight. I take it i need to adjust the tightness?
You mentioned 1/4 - 1/2 turn?
Really appreciating the help guys.  |
| Paulington |
 Posted: 20:33 - 31 Aug 2009 Post subject: |
| milkster125 wrote: | I have to admit, although the spark plug was the same one, just in Iridium, it didn't seem to screw down as far as my standard one. I screwed it as far as it would go, not hand tight. I take it i need to adjust the tightness?
You mentioned 1/4 - 1/2 turn? |
Tighten the spark plug to hand tightness and then tighten it a further 1/4-1/2 turn with a plug spanner. ____________________ "Four wheels move the body, two wheels move the soul."
| BlackStallion |
| T0MMY |
| BlackStallion |
 Posted: 20:38 - 31 Aug 2009 Post subject: |
| Paulington wrote: | | milkster125 wrote: | I have to admit, although the spark plug was the same one, just in Iridium, it didn't seem to screw down as far as my standard one. I screwed it as far as it would go, not hand tight. I take it i need to adjust the tightness?
Tighten the spark plug to hand tightness and then tighten it a further 1/4-1/2 turn with a plug spanner. |
Ah right, since i tightened it fully, do you think that is the problem, is that what tightening it to much can do?
Hopefully it will work, as getting to my plug is a pain in the arse. I'll have to invest in a spark plug spanner, just haven't got a tool which is small enough to get down the hole. The frame goes over the whole, that's why removing the cylinder head cover helps. |
| T0MMY |
| BlackStallion |
| Ariel Badger |
| BlackStallion |
| Ariel Badger |
| BlackStallion |
The last post was made 17 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
