Excess Smoke From The Exhaust
lostboy
PostPosted: 19:41 - 03 Sep 2009    Post subject: Excess Smoke From The Exhaust Reply with quote
Hi just to say hello and I need some help a mate of mine has a 50cc peugeot speedfight 2 the problem is it kicks out alot of smoke everytime its used does anyone have any suggestions on what could be causing this and how it can be remedied? thanks I look forward to your help.
With many thanks
Never invite a vampire into your house you silly boy!
Whosthedaddy
PostPosted: 20:18 - 03 Sep 2009    Post subject: Reply with quote
Because its suppose to as its a 2t?
Or am I being naive and misinformed?
Irn-Bru
PostPosted: 20:47 - 03 Sep 2009    Post subject: Reply with quote
What's it like when you've been riding it for a while? 2 strokes smoke like mad when they're cold (especially with the choke on) but that's a lot to do with the cold air and well, because it's a 2 stroke Laughing
ClaireBear
PostPosted: 21:01 - 03 Sep 2009    Post subject: Reply with quote
Random guess- something to do with the oil maybe?
tutton
PostPosted: 21:02 - 03 Sep 2009    Post subject: Reply with quote
its fucked mate sounds like its runnin on one cylinder
Finglonga
PostPosted: 21:44 - 03 Sep 2009    Post subject: Reply with quote
This!! I would put money on it. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
tonyts50 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
TUG
PostPosted: 00:16 - 04 Sep 2009    Post subject: Reply with quote
tonyts50 wrote:
they only have one cylinder ! or were you being sarcastic
and dont worry mate its nothing to worry about most 2 strokes are smokey when cold but somtime smokey when hot
did he just have a rebuild ? if so the he would of used alot of 2 stroke to lube up the barrel and piston ect so that could be another reson either way theres nothing to worry about
Guess would be he was being sarcastic...
Its a 2 stroke, should of gotten mummy and daddy to explain this to you when they bought it for you.
Haz ER-5, innit!
neil.
PostPosted: 06:43 - 04 Sep 2009    Post subject: Reply with quote
I think it's because it's one of those '2 stroke' enginethimgamibobs? I remember a thread on some forum somewhere where they talked about it lots.... Oh does that bike come with a space saver?
metalangel
PostPosted: 06:50 - 04 Sep 2009    Post subject: Reply with quote
He needs that 'scooter mechanic' from the other thread who can magically add extra cylinders to your engine.
lydanial
PostPosted: 08:33 - 04 Sep 2009    Post subject: Reply with quote
its knackered mate, really shouldnt do that at all. i would think that the red powerband has snapped (or maybe stretched too much)this will be causing the power oil to get into the engine causing the smoke.
so needs to take a wander to a mechanic, tell them your powerband is failing/failed and so you need help to stop the oil getting onto the piston.
alternatively i know someone who wants a scooter and would be prepared to fix it, how does £20 and a bottle of white lightning sound?
lostboy
PostPosted: 10:24 - 04 Sep 2009    Post subject: Reply with quote
Thanks for the replies folks, to those who said the engines meant to smoke you would note i did say 'excess smoke'. To the bloke who said £20 and a bottle of white light'ning thanks but no, lol. To the person who said a problem with the oil thats what i was thinking and to all the other sensible suggestions I thankyou most heartedly and will pass on all of the suggestions to my friend who i'm sure will appreciate all of your help, but any other suggestions will be greatly recieved.
PostPosted: 10:53 - 04 Sep 2009    Post subject: Reply with quote
Is it standard? Does it wreck spark plugs often?
Could be oil pump issues. Could also be that it is running rich (which would suggest someone has played with the jetting).
One conventional geared bikes it could also be the crank seal on the gearbox side, but not so sure with scooters.
TUG
PostPosted: 11:09 - 04 Sep 2009    Post subject: Reply with quote
Excess smoke could be down to low qualiy 2 stroke oil, Like kickstart said, oil pump might not be working or the jets have been changed or it could have 2 stroke mixed with petrol at the wrong ratio? we dont know.
Haz ER-5, innit!
lostboy
PostPosted: 11:20 - 04 Sep 2009    Post subject: Reply with quote
No as far as I am aware the bike has never had problems with spark plugs, but thanks.
tutton
PostPosted: 14:24 - 04 Sep 2009    Post subject: Reply with quote
Of course i know its a single god...
Could also be a coked up exhaust, bikes with coked up zausts always smoke worse than clear free flowing ones..
lostboy
PostPosted: 20:23 - 04 Sep 2009    Post subject: Reply with quote
no the oil's right I checked that but I reckon it could be either a leak of some sort or the oil - petrol ratio thats wrong, thing is its like it all the time and its just a hassle to my mate
baldy
PostPosted: 02:11 - 05 Sep 2009    Post subject: Reply with quote
I agree with wilson123 (for a change). They are fairly smokey. What year is it? The newer ones have a none adjustable pump unlike the older ones which have a cable operated one. It just means that the pump is stuck on full all the time making it smokey.
Sometimes the type of 2 stroke oil makes it smoke. Try changing brands.
Have you checked to see if it is burning water? Sometimes the head gasket leaks, as it's only a thin rubber ring. They are fairly easy to replace and are cheap.
One day i will rule the world, just not today.
The last post was made 17 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.06 - MySQL Queries: 13 - Page Size: 102.43 Kb
