MOT advisories
FifiTRXibelle
PostPosted: 19:22 - 08 Sep 2009    Post subject: MOT advisories Reply with quote
I've just had my bike MOTed today and it got an advisory on the "rear monoshock pivot worn but not excessive"
Now i want to replace my rear shock soon and i'm just wondering which part they are meaning whether it's the rear shock pivot shaft or the actual eye of the shock thats worn or bearings.
I want to be sure which parts to order with the shock.
Any help would be great,
Caz xxxxx
Mystery
PostPosted: 19:26 - 08 Sep 2009    Post subject: Reply with quote
isn't the pivots the top and bottem where to bolts go into were it sits?
FifiTRXibelle
PostPosted: 19:32 - 08 Sep 2009    Post subject: Reply with quote
On this bike ( xj600 diversion heap of poo) it only has one pivot point, it's a straight bolt on to the actual frame.
I'm just learning how to twirl the old spanners so i might be wrong though Embarassed
Cazxxx
PostPosted: 19:35 - 08 Sep 2009    Post subject: Reply with quote
Did the tester not explain exactly what the problem was?
Most of them do. Why not give him a ring, or pop back in and clarify. Thumbs Up
FifiTRXibelle
PostPosted: 19:41 - 08 Sep 2009    Post subject: Reply with quote
I didn't even see the tester, i 've never even seen a mechanic at the place, i swear the place is run by faries and pixies lol.
I prob will pop over and ask tomorrow. Thumbs Up
Caz xxxx
iooi
PostPosted: 20:30 - 08 Sep 2009    Post subject: Re: MOT advisories Reply with quote
Caz xxxxx
Could be either.
Unless the tester can tell you. And odds on, they will not have looked that close. Only noticed the slack, and not checked where. The best bet is to remove the old parts and have a look.
FifiTRXibelle
PostPosted: 20:49 - 08 Sep 2009    Post subject: Reply with quote
Thanks Very Happy
I'll have a poke about with it tommorrow and see if i can find anything definate.
I know the shock is toast anyway Laughing
Caz xx
yen_powell
PostPosted: 21:31 - 08 Sep 2009    Post subject: Reply with quote
It's going to be the bottom because that's probably the only one he can see as he won't dismantle anything to see the top bolt.
Usually a bearing gone, a sort of sperical ball joint type on a lot of bikes, easy to replace, it's part of the linkage rather than the shock which bolts either side of it..
XT1200Z and a DR350 in bits
The last post was made 17 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 56.04 Kb
