Sachs XTC Racing problems with starting
Sachstasy
PostPosted: 16:07 - 09 Sep 2009    Post subject: Sachs XTC Racing problems with starting Reply with quote
Hi Guys, Been a while since I've needed help or advice with a bike.
I've just been given a Sachs XTC Racing from a family friend as I'm due to do my CBT in a couple of weeks and needed a road bike for when (And IF) I pass.
They have had it since new '02', But hasn't been ridden since 2006. It was recently taken apart, (Rear cowelling, Tank, Fairing ETC).. Battery went flat and it was never started after.
It's liquid cooled, 2 stroke 125. I charged the battery, tried starting it and it turns over without a care in the world.. Although, I put fresh petrol and 2 stroke in it, tried it again and it just won't fire. I cleaned out the carb, jets, pipes etc.. And it still won't have any of it. I'm totally clueless when it comes to bikes.
Anyone know why? It sparks too Very Happy
ben350
PostPosted: 17:05 - 09 Sep 2009    Post subject: Reply with quote
Have you tried bump starting it? Sometimes bikes will start a bit easier this way.
When you cleaned out the carb did you check that the jets were actually clear?
Finally because its the 2T (TZR or DT engine) you probably need to refresh the top end with new rings or a replate and new piston kit.
Ducati 996 Biposto
Suzuki Goose 350
DT125R Supermoto (Project)
Sachstasy
PostPosted: 17:14 - 09 Sep 2009    Post subject: Reply with quote
I was thinking of doing the rings and piston anyway, It's only on 20,000 miles though?
I made sure the jets were clear, cleaned up the bowl, floats etc. I've got a mate who races bikes, he's going to come over and have a look sometime soon.
PostPosted: 21:01 - 09 Sep 2009    Post subject: Reply with quote
Only Laughing It probably is due a rebuild. Get yourself a compression tester and test the compression, then throw some 2 stroke oil down the spark plug hole and test it again. If there is a big difference between the two tests, it's a good indication that you need to replace at least the piston rings.
Sachstasy
PostPosted: 21:06 - 14 Sep 2009    Post subject: Reply with quote
Thanks.
I've gone all out anyway now, Given the engine to a mate who works for Yamaha and he's going to do a full rebuild on pocket money.. Good boy. New crank, Rod, Rings, Piston, Seals and gaskets. I said about just buying another DT engine and he said it's better this way because I'll atleast have piece of mind with knowing the internals are brand new.
Just waiting for it to be done now, Lonnnngggg. Sad
The last post was made 17 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 46.22 Kb
