could this be the answer?
rob_scott92
PostPosted: 18:14 - 10 Sep 2009    Post subject: could this be the answer? Reply with quote
hi guys,
The Gs has been feeling a bit funny recently, something i havent been able to put my finger on for a coulpe of weeks.
Some of you may remember a couple of weeks ago i had a slight oil change issue Laughing , but after i changed the oil it was running weird (as said above, ie, would take alot longer than usual to get up to speeds around the 40 mark) i checked the plug and it was white, indicating low quality oil used according to the manual (i did use asdas own cheap stuff as it was leaking at the time).
Anyways, i put some castrol GTX in and changed the plug to the correct one (a different story Rolling Eyes ) and it ran great, would go up to 60 and then even 70 with a tail wind Very Happy. Went out for a bit of a ride yesterday and on the way back it started feeling rough again, i assumed it was the wind as it was particularly windy yesterday. But this morning i started it up to go to college and as it was cold i could see that there were some exhaust coming from the bottom of the pipe, turns out theres a whole about the size of a penny, i think maybe i had run over a bit of gravel and it bounced up and left a hole there, i just dont know Sad
sorry if this has been a bit long winded just to ask but, could that be the cause of my problems? Confused
The Artist
PostPosted: 18:23 - 10 Sep 2009    Post subject: Reply with quote
Definately could be.
Holes in exhausts are not good as exhausts are designed specifically for that engine and any differences e.g. holes, length, size change the way the engine runs.
stirlinggaz
PostPosted: 18:35 - 10 Sep 2009    Post subject: Reply with quote
hi,
whereabouts is the hole on the exhaust?
one way to see if it is this hole thats causing the problems, is to do a temporary repair to the exhaust.
get someone to weld it up or....
get a couple of coke cans or baked beans cans are even better.
cut off the top & bottom with a tin opener.
cut open the remaining tube with tin snips or those cheap scissors that cut anything.(supposedly)
wrap the now flat (ish) sheet of aluminiun round the exhaust a couple of times.
some of that exhaust repair stuff might help, but some of the products arent much good.
(some exhaust repair bandage will do the same thing)
clamp it on with a couple of jubilee clips.
that should seal the hole if done right.
cheers,
GAZ
rob_scott92
PostPosted: 19:41 - 10 Sep 2009    Post subject: Reply with quote
the hole is towards the end of the exhaust, thanks, sounds like a really good way to find out if thats the problem. I'll try that 2morrow if i can get hold of some cans.
Thanks for the help
Rob Thumbs Up
Robert2014
PostPosted: 21:04 - 10 Sep 2009    Post subject: Reply with quote
At the end of those Can's they do have a Small under neff the Can Nothing to worrie about i think Can we see sum photo's please
If you require a mechanic then I am your man. Bike collection and recovery service available. Don't let a monkey work on your bike, call the family run business on 07778 873 184 01505684994 https://www.rdbikes.co.uk [email protected]
rob_scott92
PostPosted: 21:20 - 10 Sep 2009    Post subject: Reply with quote
yeah, i'll post some up when i get back from college 2morrow, i'm hoping its gonna be easily sorted Neutral
rob_scott92
PostPosted: 16:52 - 11 Sep 2009    Post subject: Reply with quote
ok here are said piccys, tell me whatcha think
thanks
Rob Thumbs Up
Finglonga
PostPosted: 18:00 - 11 Sep 2009    Post subject: Reply with quote
That's rusted through not been hit by anything. Patch it up with a baked bean can or beer can and some jubilee clips and see if it runs better. If so Time for a new exhaust.
Andy Sez....
F.Y.Y.F.F.
rob_scott92
PostPosted: 18:27 - 11 Sep 2009    Post subject: Reply with quote
Awwwww, i was afraid of that Sad .
Thanks, i'll let yas know what happens with that, probably wont get a chance to look at it till 2morrow now
Rob Thumbs Up
The last post was made 17 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 61.62 Kb
