My yamaha sr125
yamsr125
PostPosted: 18:30 - 10 Sep 2009    Post subject: My yamaha sr125 Reply with quote
hi guys
newbie here ok i have a 1995 yamaha sr 125 and today on the way to work everything was fine then loss of power and but stuttery then was fine again every now and then lack off power off the start and back fires feels like will cut out keep revs up slightly and its fine but again stutters abit
any suggestions
thanks
RichP
PostPosted: 19:09 - 10 Sep 2009    Post subject: Reply with quote
Sounds like the engines not getting enough fuel, my one used to do this...
Check you've got some in the tank lol, if thats the case your carburettor could be clogged.
yamsr125
PostPosted: 19:25 - 10 Sep 2009    Post subject: Reply with quote
got full tank of fuel filled up when it started doing it but it carried on doing it got carb off at mo full off fuel all in air filter think its where it been backfireing
smegballs
PostPosted: 09:22 - 11 Sep 2009    Post subject: Reply with quote
Check battery mounts are tight, mine used to become undone every now and then.
This caused the battery to disconnect and thus it would die each time I braked and the battery lurched forward.
Easy thing to eliminate Thumbs Up
yamsr125
PostPosted: 10:41 - 11 Sep 2009    Post subject: Reply with quote
ok checked the battery that was fine i took out spark plug and was very sooty cleaned it up seems to be running ok not perfect still bit humpty dary manual says this means its running rich what do i need to do
Gawain
PostPosted: 15:33 - 11 Sep 2009    Post subject: Reply with quote
Turn the choke off?
yamsr125
PostPosted: 15:46 - 11 Sep 2009    Post subject: Reply with quote
choke automaticaly retracts its self but choke not being used
Asharin
PostPosted: 20:59 - 11 Sep 2009    Post subject: Reply with quote
So your choke is broken too eh? Very Happy
I can't sing: https://laughinginpurgatory.bandcamp.com and https://soundcloud.com/laughing-in-purgatory
I am Dyslexic of Borg, resemblance is fertile, your ass will be laminated.
2008 Honda Dullsville 700
yamsr125
PostPosted: 00:13 - 12 Sep 2009    Post subject: Reply with quote
no choke is fine choke has self retract on it
baldy
PostPosted: 00:36 - 12 Sep 2009    Post subject: Reply with quote
He means it has a mechanical choke that flicks off when you rev. I had a fantic that did this.
Have you checked the float height? It may need adjusting or the valve may be sticking open at times.
One day i will rule the world, just not today.
yamsr125
PostPosted: 01:28 - 12 Sep 2009    Post subject: Reply with quote
i dont know how high it should be
The last post was made 17 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 65.04 Kb
