Hyosung not starting
Gawain
PostPosted: 11:23 - 11 Sep 2009    Post subject: Hyosung not starting Reply with quote
My old mans 2005 Hyo 650. Battery been marginal for a while, died properly a week ago - tried bump starting but no joy. Got it going via a jump start from a car, engine off, started no problem. Bought new maintenance free battery and fully charged it, 13.2v after standing, but the bike wont start. Dash lights up as normal but when the starter is engaged it sounds like its trying to turn but the engine wont turn ie sounds like it hits compression then stops and wont go any further. Starter gets warm and battery voltage is depressed after trying to start, 12.7v and when 'cranking'. Cant do a load test as there isnt a light switch.
Prime suspects? Im guessing starter gear or the starter itself. Any tests/suggestions/experience?
Thanks!
PostPosted: 13:35 - 11 Sep 2009    Post subject: Reply with quote
sounds stupid but my GT used to "not start" like that.
What model is it?
If you put in 2nd, roll it backwards till it locks up, then try starting it.. i know mine used to be a bastard, but when i did that it worked..1/2 the time anyway.
Try new spark plugs?
Gawain
PostPosted: 14:16 - 11 Sep 2009    Post subject: Reply with quote
Double post
Gawain
PostPosted: 14:17 - 11 Sep 2009    Post subject: Reply with quote
Thank you! Worked perfectly. Its the GT model. Is this an issue with these bikes? Had only heard of a weak clutch.
PostPosted: 19:24 - 11 Sep 2009    Post subject: Reply with quote
its not an issue as such.. i just found it a bitch to start so tried that..seemed to work alot Smile
Problems with the bike are the older ones, swing arm fails.. bit of a bugger, and the lower cc models have cam chain tensioner issues.
As far as im aware, there aren't many problems IF you keep on top of maintenance!
Dragonfly
PostPosted: 19:46 - 11 Sep 2009    Post subject: Reply with quote
This past week mines been doing that., I have a GT also. Confused Lights on, everything else dead. starts eventually, but I dont know whats causing mine yet. Mines an 07. Also prob with false neutrals Confused Says I am in neutral when I am not its still in first!
All the breast.
Muzza on Binge:
PostPosted: 19:58 - 11 Sep 2009    Post subject: Reply with quote
what CC is that? my 125 always had false neutrals, revving a bit and knocking down from 2nd worked to get it in N.
Dragonfly
PostPosted: 20:03 - 11 Sep 2009    Post subject: Reply with quote
125 also. When I go to get on it I used to start and then jump on, till false neutrals took over and my bike was once on the ground as it jumped forward. Knocked me over to Embarassed Confused had to buy a near gear lever for that one. Happened a few times after only lucky I sit on it and hold the breaks now. Its just stopped not started earlier. This is when engine is in use . Went to get stuff earlier on it and ended up sitting there like a twat hitting start and nothing happening. I kicked up and down ths stand and it did then so it maybe connected there.
All the breast.
Muzza on Binge:
PostPosted: 20:59 - 11 Sep 2009    Post subject: Reply with quote
well mate, i always start clutch in..no matter what, my old bike had the idea of thinking clutch is in and jerking forward when i hit start.. even AFTER the shop looked at it Sad
Problems with the 125s..
Cam Chain Tensioners...get erm sorted big time...
Also if possibly, up your chain and sprocket set to the 250cc ones, 520 pitch chain.. lasts alot longer, doesnt wreck as quick mate.
Apart from that, 125 GT are very very nice Very Happy any mods?
Dragonfly
PostPosted: 22:34 - 11 Sep 2009    Post subject: Reply with quote
I will get it sorted I hate being stranded and panicing,. has blue flame exhaust . I havnt really done anything to it apart from a hyosung top yoke cover (which looks perfect for the bike).
piccy.
https://i120.photobucket.com/albums/o177/CRMCC/dragonfly/th_IMG_3602.jpg
All the breast.
Muzza on Binge:
The last post was made 17 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 64.47 Kb
