| squishio |
 squishio Spanner Monkey
 Posted: 18:56 - 13 Sep 2009 Post subject: Wheel bearings - spacing issue... idea's??? |
Hi All
Just fitting bearings into the front wheel on my gpz400r ('83)
I have fitted one side and now need to do the other (speedo drive side) however I have now discovered an issue with the spacer thing in the middle.
The sequence should go...
Spacer > Bearing > Speedo driver > circlip
https://www.rdphoto.co.uk/pictures/labled.JPG
the problem is with the spacer and the bearing, see below photo....
https://www.rdphoto.co.uk/pictures/IMG_1690.JPG
You can't really see it but the spacer is higher than the bearing seat so if you were to drive the bearing down the spacer would hit the inner race of the bearing before it is fully seated.
The old bearings only just came out and there wasn't anything else in there so washers etc are out of the question. From our measurements with the bearing sitting on the spacer everything would fit (speedo driver+circlip) but we don't want to drive it down and break the bearing by putting presure on the inner race only.
Any idea's what has gone wrong?
the other side is also driven correctly as the circlip to hold it in is perfect.
Quick response much appreciated!!!
Cheers!
Rich
paint may demonstrate the problem better.....
https://www.rdphoto.co.uk/pictures/paint.png ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250 |
| Timmeh |
 Timmeh World Chat Champion
| G |
 G The Voice of Reason
| BanditsHigh |
 BanditsHigh Worse than a woman
| squishio |
 Posted: 19:51 - 13 Sep 2009 Post subject: |
pretty certain the spacer is original.
There is definately a seat for the bearing to sit on.
When the bearings came out there wasn't a noticable gap, but I can't say for sure.
I have 2 bearings, so do have one spare, so I may smack it in and see what happens, but the distance between the bearing seat and the the top of the spacer is approx 3mm so is quite considerable
what function does the spacer have? (could I lose it?) ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
| G |
| squishio |
 Posted: 11:38 - 14 Sep 2009 Post subject: |
Aha, i see it's function now
in which case can someone think of a magical solution for me  ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
| iooi |
 iooi Super Spammer
 Posted: 12:46 - 14 Sep 2009 Post subject: |
| squishio |
 Posted: 13:03 - 14 Sep 2009 Post subject: |
bearings are the same as what came out...
I hit the other side down with a big socket hitting the outer race only so the inner race hasn't moved or been touched at all
Still moves smoothly so I dont think I have knocked it or anything accidentally. ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
The last post was made 16 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
