Wheel bearings - spacing issue... idea's???
squishio
PostPosted: 18:56 - 13 Sep 2009    Post subject: Wheel bearings - spacing issue... idea's??? Reply with quote
Hi All
Just fitting bearings into the front wheel on my gpz400r ('83)
I have fitted one side and now need to do the other (speedo drive side) however I have now discovered an issue with the spacer thing in the middle.
The sequence should go...
Spacer > Bearing > Speedo driver > circlip
https://www.rdphoto.co.uk/pictures/labled.JPG
the problem is with the spacer and the bearing, see below photo....
https://www.rdphoto.co.uk/pictures/IMG_1690.JPG
You can't really see it but the spacer is higher than the bearing seat so if you were to drive the bearing down the spacer would hit the inner race of the bearing before it is fully seated.
The old bearings only just came out and there wasn't anything else in there so washers etc are out of the question. From our measurements with the bearing sitting on the spacer everything would fit (speedo driver+circlip) but we don't want to drive it down and break the bearing by putting presure on the inner race only.
Any idea's what has gone wrong?
the other side is also driven correctly as the circlip to hold it in is perfect.
Quick response much appreciated!!! Karma
Cheers!
Rich
paint may demonstrate the problem better.....
https://www.rdphoto.co.uk/pictures/paint.png
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
Timmeh
PostPosted: 19:01 - 13 Sep 2009    Post subject: Reply with quote
Now I'm no expert but shoudn't the ID of the bearing be bigger than the spacer's?
PostPosted: 19:21 - 13 Sep 2009    Post subject: Reply with quote
Should be the same.
I 'd be tempted to just try putting it in and see what happens (maybe not /too/ hard)- might be there's a little free play in the other side or something.
Is it definitely an original spacer do you know?
BanditsHigh
Worse than a woman
PostPosted: 19:25 - 13 Sep 2009    Post subject: Reply with quote
It's normal for one bearing to be inserted flush with the bearing seat of the wheel, with the second one resting on the end of the spacer slightly above the bearing seat.
The manual should state which bearing should be inserted (flush to the surface) first.
This is done so that the inner race of the bearing is always guaranteed to be in contact with the spacer, thereby ensuring the inner races/spacer/forks are clamped together tightly ... if the bearing seats were flush and the spacer slightly too short then undue pressure would be put on the outer races.
All the best ... Barry
PostPosted: 19:30 - 13 Sep 2009    Post subject: Reply with quote
That doesn't look right. The spacer looks a bit too wide for it to be meant to be like that. Drive the bearing home and it would put a massive side load on the bearing.
However on some Kawasakis (eg, ZZR600) there is no ridge on one side for the bearing to rest on, so it is possible to put the bearing in too far.
squishio
PostPosted: 19:51 - 13 Sep 2009    Post subject: Reply with quote
pretty certain the spacer is original.
There is definately a seat for the bearing to sit on.
When the bearings came out there wasn't a noticable gap, but I can't say for sure.
I have 2 bearings, so do have one spare, so I may smack it in and see what happens, but the distance between the bearing seat and the the top of the spacer is approx 3mm so is quite considerable Sad
what function does the spacer have? (could I lose it?)
PostPosted: 20:05 - 13 Sep 2009    Post subject: Reply with quote
NOOOOOO.
Ball bearings like these can only take a pretty small side load. Without that spacer when you tighten the spindle up there will be a massive side load and the bearings will be rapidly destroyed (happens fairly often when people lose the spacers between the sprocket carrier bearing and the rear wheel bearing).
While the spacer might be slightly wider I would expect a tiny fraction of a mm, certainly not 3mm.
PostPosted: 20:07 - 13 Sep 2009    Post subject: Reply with quote
Without the spacer, when you do up the spindle or similar, it will try and push the inner race of each bearing towards the centre of the wheel, generally knackering the bearings. So definitely not something you can do without!
squishio
PostPosted: 11:38 - 14 Sep 2009    Post subject: Reply with quote
Aha, i see it's function now Smile
in which case can someone think of a magical solution for me Mr. Green
iooi
PostPosted: 12:46 - 14 Sep 2009    Post subject: Reply with quote
Post in the workshop section Wink Rolling Eyes Laughing
When you put the other bearing in. Where were you hitting it....
If you have managed to hit the inner race, could be its forced it over enough to cause the spacer to sit where it is.
Assuming you have got the correct bearing. I would gently move the one that you have tapped in out a bit and then fit the other bearing and spacer.
Then carefully tap them till they are seated.
squishio
PostPosted: 13:03 - 14 Sep 2009    Post subject: Reply with quote
bearings are the same as what came out...
I hit the other side down with a big socket hitting the outer race only so the inner race hasn't moved or been touched at all Sad
Still moves smoothly so I dont think I have knocked it or anything accidentally.
The last post was made 16 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 73.02 Kb
