| Jayy |
 Jayy Mr. Ponzi
 ..... Quote Me Happy
| Jayy |
 Jayy Mr. Ponzi
| chris-red |
| Kickstart |
 Kickstart The Oracle
| Jayy |
 Jayy Mr. Ponzi
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 19:45 - 15 Sep 2009 Post subject: |
| Reuben wrote: | It may well not be the caliper but the disc.
The disc I beleive is a fully floating one. The little circles that make it 'floating' get stuck somehow(no idea what the technical term is). Put some penetrating fluid in there and go for a ride. Hopefully this will stop the overheating and pinging sound you get by allowing the disc to 'float' properly. |
Bad advice! If you put any kind of oil on there and then go ride, it will run out to the edge, across the surface of the disc, when it spins! Even if you only use tiny amounts! If you must do this, I'd think it was a better idea to sprray some on, leave it for a few hours, then clean off the entire disc with brake cleaner to make sure there's no traces of oil on anything.
I've never quite understood abou floating discs... As far as i was aware, the discs are meant to be fixed in place, totally immovable? Surely if they could move, they would wobble at speed?
It's quite likely that the rear caliper slide bolts or the caliper piston is corroded or covered in crap, stopping i moving properly, causing the brake to drag. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
 Posted: 21:28 - 15 Sep 2009 Post subject: |
| Noxious89123 wrote: | Bad advice! If you put any kind of oil on there and then go ride, it will run out to the edge, across the surface of the disc, when it spins! Even if you only use tiny amounts! If you must do this, I'd think it was a better idea to sprray some on, leave it for a few hours, then clean off the entire disc with brake cleaner to make sure there's no traces of oil on anything.
I've never quite understood abou floating discs... As far as i was aware, the discs are meant to be fixed in place, totally immovable? Surely if they could move, they would wobble at speed? |
You've first suggested I have given bad advice then admitted that you don't understand about the subject in question. Slightly contradictory. Please do some research in to floating discs, the clue is in the name.
I assumed that when applying this penetrating oil/WD40 to the bobbins the OP would be sensible enough to wipe the disc and take it easy at first.
Regardless of everything I have just said I did not pay attention to the fact the OP said it was a rear disc, which is unlikely to be fully floating in which case my advice is therefore null and void anyway. |
| Noxious89123 |
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 12:51 - 16 Sep 2009 Post subject: |
| Reuben wrote: | | Noxious89123 wrote: | Bad advice! If you put any kind of oil on there and then go ride, it will run out to the edge, across the surface of the disc, when it spins! Even if you only use tiny amounts! If you must do this, I'd think it was a better idea to sprray some on, leave it for a few hours, then clean off the entire disc with brake cleaner to make sure there's no traces of oil on anything.
It is bad advice, any oil on or near the rear disc would end up on the pads and contaminate them. The ZX6R rear disc is not floating, it's solid and mounted to the rear wheel directly.
OP, your caliper needs a strip down, if you're near Southampton I'll do it in under an hour for you. £15 plus brake fluid would cover it. Any mechanic doing that job only should be able to turn it round in well under an hour and charge about £30-40 maximum.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
The last post was made 17 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
