nsr125r g reg HELP !!!!
NSR125R-JON
PostPosted: 11:43 - 15 Sep 2009    Post subject: nsr125r g reg HELP !!!! Reply with quote
Well here we go went out to the bike started it it was on the main stand running turned it off with the kill switch took off the main stand wheeled it out started it again on side stand went to shut gate and it stopped runing didnt think anythin about went to start it again and nothin so got a kill switch and starter switch fitted that and still nothing
ANY HELP WOULD BE SOOOOO GRATEFUL PLEASE HELP ME
B10Hazard
PostPosted: 14:56 - 15 Sep 2009    Post subject: Reply with quote
Not much to go on really mate.
It just stopped and won't start again Confused
Got a spark
Got fuel
Any safety switched got stuck or something.
Lots of bikes have safety switches on the stand and things.
Is your fuel tap "off" i have done it before Thumbs Up
Fuel line blocked.
Could be loads of things ...
No longer any socks
NSR125R-JON
PostPosted: 15:40 - 15 Sep 2009    Post subject: Reply with quote
It just wont fire no noise like its even tryin recently had new starter just nothin at the start button and it aint got a stand switch
stirlinggaz
PostPosted: 18:42 - 15 Sep 2009    Post subject: Reply with quote
hi,
whats happening when you press the starter button?
nothing at all?
can you hear the starter relay clicking?
do you have power to the lights etc?
checked the fuse(s)?
is the battery fully charged? (stick a multi-meter on it)
will it bump start?
cheers,
GAZ
PostPosted: 19:19 - 15 Sep 2009    Post subject: Reply with quote
Please use full stops.
Change the spark plug and try again.
G-dawg
PostPosted: 23:31 - 15 Sep 2009    Post subject: Reply with quote
Hi im new to this.
ive just picked up an old NS125R, got the same sorta problem i think???
Had a minor electrical fault with the lights, other than that it was fine was sitting for a while so ran it on the stand then took it for a spin,fine. stopped it put it on the stand and then.....nothing.
tried starting it again, slight popping first time then nothing since.
i belive the oil pump wasnt working properly and thus not mixing,so after said period "pop" the ring blew and thats why its now doing nothing? however i am not a bike mechanic... far from it being honest and any help would be appreciated
Gazz Sad
"why do people belive you when you say there are a billion stars, but check when you say that paint is wet?"
NSR125R-JON
PostPosted: 10:45 - 18 Sep 2009    Post subject: Reply with quote
When the problem first started i tried bump startin it an it wanted to go but got annoyed with so left it . Am gettin power to the lights,indicators , horn but no clickin when i press the start button
alains
PostPosted: 13:13 - 18 Sep 2009    Post subject: Reply with quote
you should know that this bike doesnot require any voltage in the battery because it's an AC-CDI . this means that the ignition power comes direct from the alternator which has 2 coils in serial dedicated for that . if your bike doesnot bump start , i recommand to check fuel line , ignition coil terminal , sparplug
if still non starter it's more likely an alternator problem
The last post was made 16 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 55.27 Kb
