| Keir |
 Keir World Chat Champion
 Posted: 13:50 - 17 Sep 2009 Post subject: bike security |
Just bought a new house with a garage and stuff....
want to make sure the bike is safe. any suggestions for whats best? The garage is detached from the house but right next to it. its got a normal garage door on the front and a single rear door much like a front door. the bikes alarmed and disc locked. the garage has power if anything needs it.
Anyone use a garage defender on thier main door? any good?
Is a standard key lock and an added chubb lock good enough for the rear? ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| defblade |
 defblade World Chat Champion
 Posted: 14:08 - 17 Sep 2009 Post subject: |
If they want your bike, they'll take it.
Whatever you do have, use it and use it every time.
Try not to call attention to your bike..... washing out the front on a Sunday afternoon for example.
I'd consider a PIR alarm system in the garage, which sounds in the house (or even one that pages you).
Personally, I work on several cheap levels of security (needing a different set of things to crack, all a bit more trouble than "standard") rather than one expensive one. ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
BMW K1200R Sport 163bhp => Aprilia Shiver GT 750 95bhp |
| Alexio |
 Alexio World Chat Champion
 Posted: 14:19 - 17 Sep 2009 Post subject: |
I have an Alsatian that goes mental the second a stranger sets foot on my driveway. This happened once at 2 in the morning. I went outside to find one of my side panels ripped off laying on the ground and the other was still on but it was clear that screw driver had been forced in to the lock. Damn thieves! I didn't have anything fancy hidden under my side panels anyway  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| metalangel |
 metalangel World Chat Champion
 Posted: 14:24 - 17 Sep 2009 Post subject: |
Nuclear warhead (contact J. Kim, 1 People's Plaza, Pyongyang, North Korea) wired up guaranteed to stop them.
Or a ground anchor. ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
"A faired bike will get you 10x more clunge than a unfaired one." -Marlboro Matt |
| FerretFing |
 FerretFing World Chat Champion
 Posted: 14:32 - 17 Sep 2009 Post subject: |
I use a ground anchor & an Almax chain (with top of the range Squire lock)& garage alarm & alarm disc lock (Xena XN18)- 2nd Disc lock on other wheel - Abus Granite hasp/locks on the garage doors as well.
I live in an area where there`s practically no crime but I`m from a council estate in Brum originally so I`m security concious!  |
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| B10Hazard |
 B10Hazard World Chat Champion
| map |
 map Mr Calendar
 Posted: 16:06 - 17 Sep 2009 Post subject: |
Just wanted to add much of the same as been posted.
1.
Garage main door.
If up and over fit a lock into the floor.
https://www.insurancesecurity.co.uk/cart/images/ABS301.jpg
only an example, others are available at various cost
2.
Garage side door.
Fit a good lock.
Fit a padlock as well
Fit hinge bolts, go on the hinge side of door into the frame.
https://www.toolstation.com/images/library/stock/images/30917.jpg
If door is only used occasionally and not for access fit hasp and padlock to the inside as well.
If garage has a window fit with steel bars.
3.
Inside garage.
As said an alarm with PIR.
If possible link to house.
Otherwise use the cheap and chearful option of a baby monitor (check batteries often).
Fit and use ground anchor plus also chain the bike up / disc locks.
4.
Other stuff.
What is the roof made of?
My father's was once broken into and his petrol lawn mower stolen.
They broken in through the roof panels and got it out the same way (car in garage at the time).
As said, if someone really, really wants your stuff there's only a certain amount you can do.
The trick is to make it as much hassle as possible so they move on.
That said, in the attempt they may cause such damage that you'd wish they could have just taken what they wanted.
Such is life when dealing with thieving scum.
Just some thoughts.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 16:10 - 17 Sep 2009 Post subject: |
I would advise against that.
Yes they may do the job, but it advertises to the thieves that you think you have something worth nicking.
I think that a big(100dB) siren wired up to a trip wire should be enough along with the usual locks and chains.
Smoke grenade with a trip wire would also piss them off a treat.  ____________________ My Flickr |
| metalangel |
 Posted: 16:11 - 17 Sep 2009 Post subject: |
The only problem with #1 is that it's very obvious and will make the passing charver wonder what you've got in there that's so important you've put this huge lock in to stop the door being opened.
I've heard it's better to not be noticed in the first place (so a non-descript door with all your anti-thief stuff on the inside). ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
| Im-a-Ridah |
| MarJay |
 MarJay But it's British!
 Posted: 16:30 - 17 Sep 2009 Post subject: |
I've got this:
https://www.machinemart.co.uk/shop/product/details/stoppa-garage-security-lock/path/vehicle-security
Its much more subtle than the Garage Defender, and I also have three dead bolt type locks with three master padlocks.
Its a bit of a faff to open the garage but they seem to do the job. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| metalangel |
 Posted: 16:35 - 17 Sep 2009 Post subject: |
Does that go on the inside or outside? ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
| Jayy |
 Jayy Mr. Ponzi
| metalangel |
 Posted: 16:37 - 17 Sep 2009 Post subject: |
You'll only forget to lock stuff until something gets stolen. My missus' parents live in a pretty decent area yet they had their mountain bikes stolen from their garage, my parents live in an even decenter (it's a word, now) area and both neighbours either side have been burgled. ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
| Ol |
 Ol World Chat Champion
 Posted: 17:55 - 17 Sep 2009 Post subject: |
i've got a CCTV system installed round my house and an infared camera in the garage - and the recorder is networkable so if i'm not at home i can "dial" into my camera's and see what's going on (used to work for a security company - so got it all cheap!) i have a PIR in the garage connected to my house alarm, i can set part of my alarm when we go to bed, so it's armed on a night too.. and the alarm phones me if it's activated, i've got a Paxton Access control system on my garage and the gate which would take some getting through.. the bike is chained to a ground anchor and alarmed whenever it's in the garage too.. and on a night i back my car right upto the door just to be sure..
all that, and i still worry about it !
paranoid?? possibly! ____________________ Previous: Cub50, NRG50, TS50, YB100, CB125, NSR125, ZZR600, CBF1000, SV650s, ZX6R B1H, XT250, Mito Powered Crosser, WRF450, , FZ600, VN800, GSXR600 - Currently CB1000R |
| MarJay |
The last post was made 17 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
