RS 125 Powervalve
METRO_POWER
PostPosted: 19:22 - 20 Sep 2009    Post subject: RS 125 Powervalve Reply with quote
Hey all, I recently have brought an aprilia rs 125 2002 model, It is fully derestricted including the cdi unit. I am having trouble with the powervalve, its supposed to kick in at 8000rpm and give a real kick, but when i get to this magic number nothing happens. It just revs theres is no real speed increase and it sounds like im strangling the engine. I can feel the powervalve at low revs because when i get to about 5000rpm theres a boost in power to about 6500rpm. Does anyone know what the problem could be, thanks
The Artist
PostPosted: 19:32 - 20 Sep 2009    Post subject: Re: RS 125 Powervalve Reply with quote
The thing at low revs is your powerband not powervalve.
I don't know that bike but check wires are not snapped etc all the simple things first.
Kickstart will be along in a few minutes to help Laughing
METRO_POWER
PostPosted: 20:10 - 20 Sep 2009    Post subject: Reply with quote
also forgot to add, i took of fthe powervalve housing and started up the bike. i could see the powervalve moving in and out on low revs and when i took to my local garage they said its working perfectly fine. Dont know how i could have forget to tell you this... must be tired lol. is it possible for it to work at low revs and then not at high revs thanks
Noxious89123
PostPosted: 20:16 - 20 Sep 2009    Post subject: Reply with quote
METRO_POWER wrote:
Kickstart?
Knowledgable member of the forum. Is a wizard.
spitfire123
PostPosted: 16:53 - 21 Sep 2009    Post subject: Reply with quote
thanks
well if the powervalve si operationg corrctly then its likley to beither be low compression...or a mixture/fuel problem.
did you de-restrict youself?
what jets are being used in the carb?
Spit.
You won't be able to eat my dust......As it'll settle before you get there.
stirlinggaz
PostPosted: 18:16 - 21 Sep 2009    Post subject: Reply with quote
Hi,
check the pv is actually working when it should.
lift the tank & start it up. (i usually do this with a remote fuel tank & battery box removed cos its easier)
you should see the pv cable move at around 2000rpm doing its "self cleaning thing"
then it should move again at 7800rpm.
you should be able to see this happening, especially if you get the fuel tank out the way.
if its not moving when it should, try adjusting the bowden cable.
cheers,
GAZ
The last post was made 17 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 49.05 Kb
