fucked screws
Rufus
PostPosted: 00:56 - 21 Sep 2009    Post subject: fucked screws Reply with quote
after all my hard work getting the carbs off the cb (which is a pain in the dick after the lovely and spacious zx6) i found, to my dismay, that some bellend had pretty much rounded all the screws on them. what the hell do i do now?
cheers.
CG125 > ZX6r > GSX600F > CB250n + ZX7R+ Bandit 1200
hmmmnz
PostPosted: 02:27 - 21 Sep 2009    Post subject: Reply with quote
cut a notch in them with a hacksaw or a dremmel and undo them with a large flat head screwdriver,
or get some small multi-grips and grip the screw and undo them,
easy as pie,
failing that, grind the top of the screw off, and grip the shaft of the screw, they will easily undo when no weight is on them
the humans are dead
I kick arse for the lord
TUG
PostPosted: 02:38 - 21 Sep 2009    Post subject: Reply with quote
What has already been said, hacksaw grooves are excellent, double blade your hacksaw for great results. Giving them a great hit with a hammer and a punch is an excellent way aswell as it shocks the threads. Thumbs Up
Haz ER-5, innit!
Alexio
PostPosted: 02:52 - 21 Sep 2009    Post subject: Reply with quote
If the screws really are fucking (screwing?) as you have claimed in your title, then once you have extracted the old screws and they have finished reproducing you will have some nice new screws to replace them with Thumbs Up
I apologise for the above sentence. It's kind of late.
Rufus
PostPosted: 15:26 - 21 Sep 2009    Post subject: Reply with quote
easy as pie,
cheers, men Thumbs Up off to the garage to put this into practice and to order some stainless steel hex screw replacements Smile thanks.
fucked screws, not fucking screws. your humour needs a bit of work Thumbs Up
Alexio
PostPosted: 15:36 - 21 Sep 2009    Post subject: Reply with quote
Again, I can only say sorry. I was hallucinating by that hour of the morning. Also, a hammer really can fix most things Cool
PostPosted: 15:46 - 21 Sep 2009    Post subject: Reply with quote
Although hitting Japanese carbs with a hammer is a risky business, the alloy is fragile at best. They crack easily. Especially on the flange around the float bowl where the screws are.
Rufus
PostPosted: 18:53 - 21 Sep 2009    Post subject: Reply with quote
managed to clean out the carbs and put em back, now bike won't start Mr. Green any ideas?
PostPosted: 21:24 - 21 Sep 2009    Post subject: Reply with quote
Is it a vacuum fuel tap? Need the float bowls priming?
Cracking open the drain screws and making sure there is fuel getting through is a good first step anyway.
Rufus
PostPosted: 12:42 - 22 Sep 2009    Post subject: Reply with quote
right, there's fuel going into the carbs. what now? i really am a retard at this.
PostPosted: 13:24 - 22 Sep 2009    Post subject: Reply with quote
Check it still has a spark. Check the condition of the sparkplugs (they should be wet if you've been trying to start it for a while).
I sometimes find an engine needs a few drops of fuel putting down the sparkplug holes the first time you restart it after working on it. No idea why but worth a try.
Rufus
PostPosted: 13:48 - 22 Sep 2009    Post subject: Reply with quote
will give it a look in a minute after i've been relieved of looking after the kids Thumbs Up
otherwise i guess i'll just buy a new carb Sad
Rufus
PostPosted: 14:47 - 22 Sep 2009    Post subject: Reply with quote
no change in spark plugs. tried dropping fuel, still nothing. every time i kick it there's not even the slightest sign that the bike wants to tick over, or even a splutter then death. it just won't start lol.
PostPosted: 15:16 - 22 Sep 2009    Post subject: Reply with quote
So the plugs are dry but fuel is getting to the float bowl? Thinking
Tends to suggest either a massive air leak so there is no vacuum through the carbs (try putting your hand over the choke end as you turn it over, it should suck your hand against the carb) or that one or more of the jets are blocked.
If there is suction throught the carb, fuel in the carb and an open jet, fuel should be getting into the engine and at least making the plugs wet and the exhaust smell of petrol.
Are they CV or slide carbs on your bike?
Rufus
PostPosted: 16:26 - 22 Sep 2009    Post subject: Reply with quote
i have no idea what carbs they are lol. it's a 1980 cb250n...
Chriss
PostPosted: 17:11 - 22 Sep 2009    Post subject: Reply with quote
Does your throttle cable pull the metal sheet in the carbs open directly?
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Rufus
PostPosted: 17:16 - 22 Sep 2009    Post subject: Reply with quote
aye.
Chriss
PostPosted: 18:45 - 22 Sep 2009    Post subject: Reply with quote
Slide carbs then.
PostPosted: 20:15 - 22 Sep 2009    Post subject: Reply with quote
Chriss wrote:
Slide carbs then.
Maybe not!
I've just been looking at some pictures, I think they are CV carbs with a solid slider.
https://www.zed-parts.com/images/ZP_ultra_sonic/CB250_carbs_1.jpg
Did you totally strip them or just take the float bowls off?
There is a vacuum chamber in the top part of these carbs, the suction of the engine lifts the throttle body and allows the fuel/air to pass through according to how open the butterfly operated by the twistgrip is. It's normally via a rubber diaphragm attached to the throttle body but I seem to recall there being some other arrangement on that type. I've never had dealings with them so I'm unsure what it is.
In any case, probably worth checking it is all moving freely and is undamaged. If there is a diaphragm, treat it with care, they are delicate, any holes or tears and they need to be repaired or replaced.
GREEN KMX
PostPosted: 08:21 - 23 Sep 2009    Post subject: sometimes stud extractors actually work. Reply with quote
I managed to remove this rounded off gear change sprocket with a square stud extractor without breaking anything. Cool.
she's alive!!!!
Xenocide
PostPosted: 12:55 - 23 Sep 2009    Post subject: Re: sometimes stud extractors actually work. Reply with quote
What address would you like the medal sending to?
KTM LC4 400 | Honda VTR1000
Rufus
PostPosted: 13:16 - 23 Sep 2009    Post subject: Reply with quote
BLUEX5 wrote:
The pooper dream uses horrific CV carbs which rely on the clearance between the slide and the bore of the carb to provide vacuum lift, hence they are a pile of shit once a bit of wear kicks in. However if it was running before then this might not be your problem.
however i probably knocked something out of whack trying to get the screws out knowing me Neutral i've ordered a new set of carbs anyway and if that doesn't solve it i'm just gonna have to cry all the way to the local mechanics.
The last post was made 16 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 125.38 Kb
