Basic Motorcycle Electrical Query (bench testing)
twotakt
PostPosted: 12:52 - 21 Sep 2009    Post subject: Basic Motorcycle Electrical Query (bench testing) Reply with quote
Got a spare motor that I want to chuck into a chassis, just gone over it replacing gaskets, tensioner, cam chain, clearances etc but want to check the compression. However to do this I need to turn over the motor on the starter, how do I go about doing this on the bench rather than in the frame? I don't want to plug it all in and realise that I need to take it out of the frame again in order to re-ring it.
Would it be a case of getting a 12v battery, connecting to the starter solenoid and then onto the starter motor? Would there be a need for an inline fuse and an earth? Sorry if it all sounds stupid, evidently I'm a pure noob when it comes to these matters lol.
R.I.P. Tareree Shiimi, 1985-2008
PostPosted: 13:01 - 21 Sep 2009    Post subject: Reply with quote
Crudely, hold the engine steady (and I would put it somewhere easy to hold , and where if it falls it will not damage / injure anyone or itself), one jump lead from the engine to the earth terminal of the battery and another from the +ve terminal to the starter motor terminal.
Make sure that there isn't anything in the ports that could get sucked in.
twotakt
PostPosted: 15:27 - 21 Sep 2009    Post subject: Reply with quote
Ta Keith, just done it now. 150psi on all 4 pots ftfw Smile
It only moved a bit, might just be prob on bigger motors? I dunno.
steven_191
PostPosted: 16:37 - 21 Sep 2009    Post subject: Reply with quote
ideally when its turning at a constant speed you wont have much movement or vibration as long as the bearings are good and its well balanced. Thumbs Up
The last post was made 17 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 40.44 Kb
