R1 fork conversion
Damon
PostPosted: 12:11 - 21 Sep 2009    Post subject: R1 fork conversion Reply with quote
Hi all,
I recently purchased a 99 R1 and was wondering if the newer forks (with radial brake mounting) would fit my yolks/wheel etc. as I would like to upgrade my brakes without spending a fortune on new calipers. Rolling Eyes
Thanks,
Damon
Damon
PostPosted: 17:37 - 21 Sep 2009    Post subject: Reply with quote
anyone Smile
Bikeless
PostPosted: 17:43 - 21 Sep 2009    Post subject: Reply with quote
Are 99 R1 brakes really that crap?
temeluchus
PostPosted: 18:13 - 21 Sep 2009    Post subject: Reply with quote
I suspect the new radial jobs arent much better than the quite frankly awesome Sumitomo Blue spots on your R1.
I fitted a set of 1999 Blue spots from an R1 onto my later model FJ1200 and they could stand that massive bus on its nose. Christ knows what it must be like on an R1 or R6.
If they arent feeling great, then new pads and fresh fluid should get it going.
Sgoaty
PostPosted: 18:14 - 21 Sep 2009    Post subject: Reply with quote
I thought the blue spot calipers were meant to be some of the best. Have you thought about a change of pads and braided lines?
Fair enough if you just want some bling Mr. Green
Scott
ZZR1400
PostPosted: 18:57 - 21 Sep 2009    Post subject: Re: R1 fork conversion Reply with quote
You can make most such things fit, but there's varying levels of difficulty.
I really can't see why you'd need better brakes than the blue spot ones in good condition. So, if they're not, I'd sort them, then consider some after market fork internals if you want better suspension too.
Should be much cheaper and easier; so more riding time, though less tarty.
temeluchus
PostPosted: 19:23 - 21 Sep 2009    Post subject: Reply with quote
They can stoppie a FJ1200.....
400bandit
PostPosted: 19:40 - 21 Sep 2009    Post subject: Reply with quote
Have you already got braided lines? they make a big difference, coupled with a general overhaul (i.e. new seals and a general clean up) you would notice a marked improvement.
Joe
PostPosted: 02:49 - 22 Sep 2009    Post subject: Reply with quote
Another vote for blue spots being the tits.
Damon
PostPosted: 09:10 - 22 Sep 2009    Post subject: Reply with quote
fair enough, they may just need a overhaul and new pads/fluid. Yep braided lines are fitted. They arent bad, I was just wondered if it was easy fit to get some nice radials on there. Thumbs Up + a been offered a pair going cheap, so thought it might make a nice upgrade
Alex_H
PostPosted: 10:18 - 22 Sep 2009    Post subject: Reply with quote
In reply to your actual question, 2004+ forks will fit straight into your original yokes, but you'll need the 2004+ wheel, axle and discs etc, because the later bikes used 320mm discs.
The 320mm discs over your original 300's will be where the extra braking performance will come from if there is any.
Also if you wanted to fit a 2004 onward wheel on the back to match, you need the caliper hanger from a 2003 bike as the rear disc is a different size. Rumour has it you can keep your original hanger however if you use an fz1 rear disc but I dont think anyones actually tried...
1998 r1, ccm 644 ds, 2000 r6 ghetto track bike
Damon
PostPosted: 05:56 - 23 Sep 2009    Post subject: Reply with quote
nice one Alex
The last post was made 16 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 71.33 Kb
