Electrical problem - CB250RS
Mudskipper
PostPosted: 14:03 - 21 Sep 2009    Post subject: Electrical problem - CB250RS Reply with quote
I'm prepping the CB for MOT and there's a problem with the lights and indies. It's a kickstart '81 CB250RSA.
Arrow Headlight will not come on
Arrow Bulb is intact, and will light up when the 'PASS' button is held
Arrow All fuses intact
also
Arrow Just replaced the parking light (tiny bulb) as the filament was blown, but that isn't coming on either
also
Arrow indicators all work and flash normally on tickover, with any revs they dim/come on and stay on (not flashing).
I am charging the battery now to see if that helps, any other ideas I may have overlooked? Or is it simply a battery issue?
Cheers
PostPosted: 14:07 - 21 Sep 2009    Post subject: Reply with quote
Doubt the issue with the lights is the battery given they work when the passing light is pressed. However would need a wiring diagram to confirm this.
However a dodgy battery and charging system could well be the issue with the indicators.
Mudskipper
PostPosted: 14:13 - 21 Sep 2009    Post subject: Reply with quote
Annoyingly, the Haynes manual and wiring diagram are what the seller forgot to bring with the bike so I don't have them at the moment.
Will have a look for an online wiring diagram.
edit: found it
https://img.photobucket.com/albums/v246/super_jo/cb250rs_wiring.jpg
PostPosted: 14:34 - 21 Sep 2009    Post subject: Reply with quote
Looking at that it looks like the passing switch is wired directly to an output from the regulator / rectifier unit without a fuse.
The main switch takes a feed from the same feed, but then passes the supply via a fuse.
Think you will need to probe with a multimeter. First step would be to check for voltage at the fuse.
The last post was made 17 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 42.22 Kb
