Aprillia rs125 idling problem?
Ozwald
PostPosted: 22:40 - 20 Sep 2009    Post subject: Aprillia rs125 idling problem? Reply with quote
I recently got myself a second hand rs125, and its idling seems really odd. It either idles really high (5k+) or so low that it just cuts out.
Is this a common problem and anyone know why it happens?
Thanks in advance.
TUG
PostPosted: 00:33 - 21 Sep 2009    Post subject: Reply with quote
could be a vast number of reasons, the mixture settings might be off, when was it last rebuilt?
Haz ER-5, innit!
Ozwald
PostPosted: 17:29 - 21 Sep 2009    Post subject: Reply with quote
Never really, its the 56 plate so pretty new in itself, I'll have a look at it some more, check the mixture and see what else I can find but neither me or a bike fanatic friend have any idea whats up.
stirlinggaz
PostPosted: 18:01 - 21 Sep 2009    Post subject: Reply with quote
hi,
have actually tried adjusting the idle?
or has someone been playing around with it?
take the carb off.
give it a good clean & blow throw with compressed air.
(while its apart,take a note of what jets are in it)
re-assemble & return to stock settings,. (needle clip on 2nd notch & air/mixture screw 2 & 1/2 turns out,iirc)
turn the idle adjuster screw all the way in & then back it out a bit.
get it warmed up, & then keep unscrewing idle screw until you get it to around 1200rpm.
check/clean the air filter while your at it.
chuck a new spark plug in & then plug chop.
cheers,
GAZ
The last post was made 17 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 42.71 Kb
