RS 125 - high idle revs
Oz.
PostPosted: 14:33 - 21 Sep 2009    Post subject: RS 125 - high idle revs Reply with quote
Hmm recent issue cropped up on the rs, when pulling up to lights/junctions/drive way the bike will idle at around 3k revs and after a while will drop back down to 1,5k.
If I slowly release the clutch to the biting point while in gear and then pull it back in again then this will cause the revs to drop back to 1.5k again.
Any ideas?
PostPosted: 20:07 - 21 Sep 2009    Post subject: Reply with quote
my gs has done that for ages, tbh i do exactly the same, get in gear, clutch out, revs drop..
i let the bike warm up, no knocking noises anywhere, idle is set to 1600rpm.. yet it jumps to 3/3.5k at lights etc when warm...
Strange a few people are having the same issue Sad
tutton
PostPosted: 20:33 - 21 Sep 2009    Post subject: Reply with quote
Can means loads some people say a dragging clutch
others which seems more likely on a tuned 2 smoke is its running slightly lean, so as your letting off the power its getting less fuel and more air to fuel makes a bike rev higher.
Oz.
PostPosted: 16:13 - 22 Sep 2009    Post subject: Reply with quote
Have done plug chops and they be fine if not looking a little like its running slightly rich.
So this dragging clutch issue, what is it exactly and how could I test for it?
The last post was made 17 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 39.77 Kb
