| binge |
 binge Emo Kiddy
 Posted: 16:48 - 21 Sep 2009 Post subject: Bit of a scare with the TZR engine |
Before I rebuilt the engine (TZR125 2RK engine), It kept nipping up on me.
Now it was getting oil as I was using the oil pump. So I assumed it was down to the already tight bore / previously scored barrel, And a problem with the running.
However, This morning I stupidly let the oil tank under my seat run dry.
It had only just ran dry because there was still some oil in the pipe work running to the carb.
It bogged down, and felt like I'd started to apply the rear brake from around 30mph.
I clutched in, And rolled to a stop, Engine cut out.
I tried to start it again, It fired straight up, But when I realized what had happened, I turned it straight off. And pushed it to my local bike shop.
I then had to sit outside for half hour until they opened up. I bought a bottle of 2t Oil, And stuffed about 10ml in the half empty tank.
Shook it about a bit, And it started up on the kick.
I rode it to a petrol garage, Where I filled it up with petrol, And stuck another 50ml or so of oil in the tank.
Now I've ridden it 5 miles to work, And 6 or 7 miles home tonight (Since the "seizure")
And its been sound as a pound.
Although I've also filled up the oil tank, And bled the oil lines through.
It's running smokey, But as a 2 stroke should. And come to think about it, It wasn't really running very smokey before.
So I am wondering weather my oil pump could be faulty?
I've got the cable bias on the richest oil setting. But when you full throttle it, You can still pull the oil cable a little bit more, I'd say 1/4 turn left on the oil pump when at full throttle on the carb.
But you physically cant tighten the oil cable up any more.
Do oil pumps become "on their way out", And then eventually stop pumping?
Or do they work one minute, And the next not?
It's definitely working because I had the bike on idle, I pulled the oil pump cable tight and you could see the oil pumping through the line.
I'm a bit pissed off, And a bit confused at the same time.
The bike is running spot on other than that. Plug is burning slightly rich, But I've a feeling its still sucking in gearbox oil as that seems to be disappearing.
I dont really want to run pre-mix because it means lugging a bottle of 2t around with me. Unless anybody knows if they sell 2t in 100ml capsules.
Ben |
| Kickstart |
 Kickstart The Oracle
| binge |
 binge Emo Kiddy
 Posted: 17:05 - 21 Sep 2009 Post subject: |
It just didnt seam to be very 2 stroke'y when it was running on the pump alone.
When a DT125 / RS125 passes my workshop. I can smell the 2t in the air, And I can see the smoke from the exhaust.
My pit bike doesn't do either of these.
And premixing on a 3L tank is not practical really. |
| Blau Zedong |
 Blau Zedong Banned
| Pete. |
 Pete. Super Spammer
 Posted: 15:34 - 22 Sep 2009 Post subject: |
If it wasn't working it wouldn't have emptied the oil tank. If you want it to smell really nice put castor oil in it  ____________________ a.k.a 'Geri'
| Blau Zedong |
 Blau Zedong Banned
| binge |
 binge Emo Kiddy
 Posted: 18:35 - 22 Sep 2009 Post subject: |
| Billing |
 Billing World Chat Champion
| binge |
 binge Emo Kiddy
| Pete. |
 Pete. Super Spammer
 Posted: 19:56 - 22 Sep 2009 Post subject: |
Not familiar with the TZR but every one I ever set had marks on the oil pump quadrant that must align at full throttle. ____________________ a.k.a 'Geri'
| binge |
 binge Emo Kiddy
 Posted: 19:58 - 22 Sep 2009 Post subject: |
Shit, I didn't know that!
I'm worried now in case its the sort of pump that if opened past the "Max" mark, It actually slows down the flow rather than keeps increasing.
Better check that before I ride it next.
Cheers Geri.
Oh, By the way, I'm off up the Ebbsfleet roundabouts tomorrow, Bring the busa Turbo. I'll race ya.
Ben |
| G |
 G The Voice of Reason
 Posted: 20:41 - 22 Sep 2009 Post subject: |
For pre-mixing, an appropriate sized bottle with graduations in litres of petrol marked on it should make it pretty hassle-free when filling up - and not going to take up much more room than a 2 stroke tank of the same capacity.
Recently I've been running my zx9 on old 2 stroke to really confuse people . |
| binge |
 binge Emo Kiddy
 Posted: 00:04 - 24 Sep 2009 Post subject: |
Looks like I am going to have to run pre-mix on this bike.
I didnt realise how small the oil tank is on the bike. I managed to nip it up again tonight.
PROPER Fucked off. Was riding home from Ebbsfleet, Came off the A2, Joined the Waynescott Bypass and it nipped up as I came off the slip road onto the Dual Carriage way.
So I then had to push it 6 maybe 7 miles to the petrol station by the Medway tunnel.
CUNT.
I've JUST got in now, I set off home from ebbsfleet just before midnight. SO its taken me nearly 2 hours to do the 10 mile ride.
Anyway, Got to the petrol garage, Bought a bottle of 2t, Filled up with petrol and slapped loads of oil in the tank. Shook it about, And got it going.
I let it idle until it'd used the petrol in the float bowl and started using the petrol which is now mixed with oil.
Meh, Maybe 2 strokes just arent for me, I have a brain like a sieve.
The oil tank has literally lasted 60 miles of riding (6 liters of petrol, 3 tanks).
The oil tank is an old rad header tank from the TZR, It's under the seat. The only place I can fit it.
I have to unbolt the seat to top it up.
And I must of just forgot, Again.
The bike was really boggy (I mean really boggy) when I started riding home from the petrol garage.
I hope this is down to having nearly 200ml of oil in the 3 litre petrol tank rather than loss of compression.
As soon as I felt the engine tighten up, I clutched in and hit the kill switch.
Proper pissed off.
So am I right in thinking. Carry a bottle of 2 stroke around with me.
I try and fill up every 20 miles anyway because the tank only holds 3 liters (From dry), And I cant really use the last 1/2 litre because of how high the carb sits.
If I was to put around 50ml of oil in the tank every time I fill up with my petrol (I put 2 litres in when I fill up).
This would be running at 40:1 ratio?
Is that too Lean?
Ben
Ben |
| binge |
 binge Emo Kiddy
| serlant |
 serlant Brolly Dolly
 Posted: 00:57 - 24 Sep 2009 Post subject: |
My understanding is that going from the oil pump to premix will lean the mixture out a little as oil is now taking the place of some of the petrol being sucked in through the main jet, i doubt it atomises aswell either, which might be why it was boggy, if it leans it out too much it could cause damage(as spitfire 123 found out), STOP forgetting. |
| Kickstart |
| G |
| Blau Zedong |
 Blau Zedong Banned
| Pete. |
 Pete. Super Spammer
 Posted: 11:21 - 24 Sep 2009 Post subject: |
Fit a bigger reservoir and keep the pump. Might as well if you are going to use up your storage space carrying a bottle. Get in the habit of checking the oil each time you lube the chain. ____________________ a.k.a 'Geri'
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
 Posted: 12:15 - 24 Sep 2009 Post subject: |
Just found an air box which would probably fit if I shortened the snorkel to it.
Would this be big enough?
https://i8.ebayimg.com/02/i/000/e1/5e/f4b7_1_sbl.JPG
LENGTH 32.5CM
BOX LENGTH 15.5CM
BOX HIGHT 13CM
BOX DEPTH 10CM
Ben |
| Kickstart |
 Posted: 12:39 - 24 Sep 2009 Post subject: |
Looking at your bike, do you ever fully compress the back wheel so it is close to touching the mudguard? If not could you mount a tank under there. Or even have the tank forming part of the rear mudguard (almost how the RS125 tank mounts).
If you are using up a full tank of 2 squeak oil in 6 litres of petrol, even at 30:1 that makes your oil tank only 200cc. That is tiny.
| binge |
 binge Emo Kiddy
| Pete. |
 Pete. Super Spammer
 Posted: 13:13 - 24 Sep 2009 Post subject: |
Doesn't have to be mounted on the bike. You could use an upside-down colostomy-bag full of oil worn in a shoulder-holster that no-one wants sinced they banned handguns  ____________________ a.k.a 'Geri'
| binge |
 binge Emo Kiddy
The last post was made 16 years, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
