CX500 electrical fault?
CXrider
PostPosted: 01:16 - 22 Sep 2009    Post subject: CX500 electrical fault? Reply with quote
Hi all
I had a friend weld the frame on my CX500 last saturday,I took the usual precautions of removing battery and disconnecting the reg/rect unit from the frame aswell as un-plugging it from the wiring loom.after the work was done,I put everything back togeher and rode the bike home.it went fine with no problems,however,the next day was a diffrant story.I took the bike on a 7 mile journey and after the first mile the bike began to run like it was running out of fuel.I switched over to reserve as I knew I was getting low,but,the bike still coffed and splutterd like the fuel wasnt getting through.
anyway......
I just got to where i was going and the engine just cut out on me.I spent a good 10 mins turning it over before giving up and leaving it for an hour.I tried again after an hour,but still it wouldnt fire up.I took a spare spark plug out from under the seat and checked to see if i was getting a spark,it was very weak if anything.it was then after having the seat up that I noticed that I had not connected the reg/rect unit.I connected it to see if it would work but still bugger all! I left the bike for another hour and after a lot of head scratching,i went for another try.the damn thing started at the press of the button!!!! I stopped it with the cut off switch and tried it starting it again,it wouldnt even fire!!!!
Sorry for the long winded story,but does anyone here have a clue??? any help would be appreciated as im missing my wheels already......thanks in advance Smile
PostPosted: 02:34 - 22 Sep 2009    Post subject: Reply with quote
Give the battery a charge.
CXrider
PostPosted: 11:06 - 22 Sep 2009    Post subject: Reply with quote
I charged the battery up yesterday afternoon,its a yuasa heavy duty one,loads of life left in it.its not made any diffrance mate
temeluchus
PostPosted: 11:56 - 24 Sep 2009    Post subject: Reply with quote
check the connections to the ignitior and coils are clean and properly connected.
Had a mates bandit 400 do the same due to a little corrosion on a block connector. It was ok until he disconnected and reconnected it and that moved the corrosion enough to provide enough seistance to cause issues.
The last post was made 16 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 40.12 Kb
