nsr125- precautions after rebuild? anyone????
taz4626
PostPosted: 19:26 - 25 Sep 2009    Post subject: nsr125- precautions after rebuild? anyone???? Reply with quote
hi guys ive had to take my entire engine apart including the crankcase and its been apart for about a week.
what im after is is there anything i should do before trying to start it ie. 2 stroke oil down the spark plug hole a dry run with the kill switch on the get things moving before starting.
all i have replaced is a bush on one of the gears and a shifter fork everything else is the same parts as before. Also will it need a run in period as its been apart to allow everything to seat properly or will it just be good to go?
cheers in advance - rob
hmmmnz
PostPosted: 22:57 - 25 Sep 2009    Post subject: Reply with quote
make sure your 2 stroke oil pump is primed,
other than filling your gearbox back up,
she should be good to go,
the humans are dead
I kick arse for the lord
taz4626
PostPosted: 07:08 - 26 Sep 2009    Post subject: Reply with quote
im guessing by primed you mean bleeding the air out of the 2t pump?
hmmmnz
PostPosted: 07:17 - 26 Sep 2009    Post subject: Reply with quote
yeah essentially, make sure that the oil line(s) that feeds the engine are filled with oil,
you wouldnt want it run with no oil, that would be bad,
if you are particuly worried, run a couple of litres in the tank on premix untill the pump forces all the oil through
the humans are dead
The last post was made 16 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 40.87 Kb
