What to say to this?
GSXRk2 This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
GSXRk2
PostPosted: 20:48 - 25 Sep 2009    Post subject: Reply with quote
..........is this true?
Darth
PostPosted: 20:52 - 25 Sep 2009    Post subject: Reply with quote
You have started a thread about a conversation between you and some ned and what - are you really asking someone else to finish it for you? I'm slightly confused Confused Do you want to buy the car or have you just been spamming up his ad thread somewhere?
He does have a bit of a point though. My mother always seems to bugger her cars before their time by never exceeding 3500 rpm and always being in too high a gear. That said obviously the reverse will be be equally if not more detrimental to the health of an engine.
Seeing as that is what you are accusing him of maybe you should point that out to him?
AngelGrinder
PostPosted: 21:00 - 25 Sep 2009    Post subject: Reply with quote
What I would say is -
Confused
delvey91
PostPosted: 21:11 - 25 Sep 2009    Post subject: Reply with quote
So you still cant find the logout button?
2016 Honda Africa Twin
2006 KTM 200 EXC
KevTM
PostPosted: 21:14 - 25 Sep 2009    Post subject: Reply with quote
Your first post in a bike forum is this? Laughing
Engines should be used just not abused.
PostPosted: 21:31 - 25 Sep 2009    Post subject: Reply with quote
Unless up to temperature, then rag the crap out of it, but don't exceed the red line. Nothing wrong with that.
GSXRk2
PostPosted: 08:53 - 26 Sep 2009    Post subject: Reply with quote
anyway ..i cant think of anything cnutish enough to say back.. mainly because i dont really know fck all about cars. Laughing Embarassed (as delvey91 will know)!.. Is he right or not? I'm assuming it's only in extreme cases where opening it up with 'clear the valves' etc not on a crappy little fiesta/zetec or whatever the funk it is and he's just giving an excuse to drive like a nob.?..
Anyway.. if he's so concerened about keeping his engine good.. he would have had the engine balanced/fuelling set up correctly etc for the engine to run properly with the lump of metal he's got bolted on the end of his zorst?..or this only mainly with bikes?....
tutton
PostPosted: 15:08 - 26 Sep 2009    Post subject: Reply with quote
Dosnt matter what it is, opening it up once in a while does it good, good example of this is 2strokes, yeah fine your not supposed to rag them, but if you dont open them up once in a while you get all sorts of problems with powervalves sticking and gumming up etc.
For a backbox or just downpipe to backbox exhaust it wont need rejetting on a car.
So hows devonbikeriders then?
PostPosted: 22:43 - 26 Sep 2009    Post subject: Reply with quote
Why are you even bothering to converse with the guy?
GSXRk2
PostPosted: 15:31 - 27 Sep 2009    Post subject: Reply with quote
did mummy take your bike away tutton? Sad
tutton
PostPosted: 18:38 - 27 Sep 2009    Post subject: Reply with quote
Yeah she told me theres enough fucking idiots like you on the road tom Laughing tits like you getting yourself splattered up trees and the like dont project a good image do they? Wink
So then raced any more ferrari's lately?
smegballs
PostPosted: 19:17 - 27 Sep 2009    Post subject: Reply with quote
Know as a "Ferrari Tuneup"......
Supposedly the mechanics would do your normal service then go thrash it for a bit to get it nice and hot.......
On asking various mechanics they seem to differ a bit normally....
When the mechanic in question is a quick driver with his evo, it apparently does the engine a world of good....
Also he said something about an engine which is always low revs can build up a wear ridge on the bore at a lower height that one that is ragged. If one was to the rag the low revved engine the rings would collide with the lower wear ridge and possibly chip/crack. Or so the theory goes.....
metalangel
PostPosted: 07:37 - 28 Sep 2009    Post subject: Reply with quote
I'm told that the TDI engines used in VAG cars need a good ragging to stop the turbo vanes sooting up. The chap in question on the TDI forum goes so far as to say that once you're warmed up you should be shifting at 3,000rpm (redline is 5,000).
For a Transit van, maybe, but a 110bhp car it seems a bit much. Tis fun, though.
truslack
PostPosted: 09:28 - 28 Sep 2009    Post subject: Reply with quote
I think there's a rule against signing up again after your account is banned?
PostPosted: 11:59 - 28 Sep 2009    Post subject: Reply with quote
There are rules on in breeding too, hasn't stopped this fool.
Kwaks
I'm not a fast rider
PostPosted: 12:34 - 28 Sep 2009    Post subject: Reply with quote
Who is this twat then?
www.cliqueycuntsmcc.co.uk
truslack
PostPosted: 12:44 - 28 Sep 2009    Post subject: Reply with quote
The guy that spammed with the Devon Bikers forum.
(pretty sure it is anyway, and he owns a GSXR K2)
Ol
PostPosted: 14:28 - 28 Sep 2009    Post subject: Reply with quote
That's 100% bullshit !
The piston reaches TDC on every single stroke.. regardless of how many revolutions per minute it's doing.
If a "mechanic" has told you this, he is either trying to wind you up, or he's a fucktard who shouldn't be allowed to operate a spanner !
smegballs
PostPosted: 15:25 - 28 Sep 2009    Post subject: Reply with quote
No but there is slight more stretch in the conrods and bearings etc at high rpm than low rpm. We're talking fractions of a mm.
It follows that the piston rings only go a certain way up the barrel if an engine has only low revs. When the revs are higher all of a sudden, that slight stretch in the conrod etc means the rings move a fraction of a mm that they're not used to and collide with the wear ridge, this chipping them.
Its also why engine have a squish clearance (apart from gas flow and cooling), theres a enough room between the head and piston at low revs so they don't collide at high revs.
A "perfect" engine wouldn't have a squish (if cooling was ignored) as it is effectively a "waste" of compression. The gas in the squish band, that normally doesnt burn (although the unburnt gas does aid cooling), could be put to better use if it was all crammed into the combustion chamber.
sickpup
Old Timer
PostPosted: 21:16 - 28 Sep 2009    Post subject: Reply with quote
GSXRk2 wrote:
Anyway.. if he's so concerened about keeping his engine good.. he would have had the engine balanced....
So you've stripped your engine and had the internals balanced then?
Ol
PostPosted: 08:08 - 29 Sep 2009    Post subject: Reply with quote
Bittern wrote:
Its also why engine have a squish clearance theres a enough room between the head and piston at low revs so they don't collide at high revs.
You don't know what your talking about.
Before you make a complete tit of yourself :
https://1.bp.blogspot.com/_v948kvMs9PU/SGVblh9vzXI/AAAAAAAAABE/Buv2EFthu2E/s320/Theres_The_Door.jpg
Mr.Everready
PostPosted: 08:18 - 29 Sep 2009    Post subject: Reply with quote
Didn't stop Siggi, did it ?
truslack
PostPosted: 08:26 - 29 Sep 2009    Post subject: Reply with quote
True, but Siggi isn't as much of a twat.
(and the siggi banning was way before my time, I'm a 2007 noob)
Mr.Everready
PostPosted: 09:48 - 29 Sep 2009    Post subject: Reply with quote
As you said, you wern't here at the time.... Wink
The last post was made 16 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.75 - MySQL Queries: 15 - Page Size: 128.18 Kb
